Troubleshooting Passat B6 Window and Xenon Washers: Fuse and Relay Checks
dimcar7 10323 2
  • #1 17067102
    dimcar7
    I have the same problem, the wipers work, but the window washers and xenon washers are not working
    I checked the fuses, checked this relay (I replaced it) and nothing.
    Any hint ??
    Thanks
    Moderated By CameR:
    Reg. 3.1.15. Do not ask immediately on the forum if you have not checked anything yourself or have not attempted a self-diagnosis. Remember that advice is provided remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and a brief description of the fault.
    Reg. 3.1.19. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
    Separated from: https://www.elektroda.pl/rtvforum/topic3406977.html#16879444
  • #3 17067592
    dimcar7
    Solved
    from the windows - the liquid froze
    from xenons - a pump fell
    Thanks
