[Solved] Recording Series on EVOBOX PVR Decoder: Tips for Cyfrowy Polsat and Avoiding Reruns
rencistka 7041 2
  • #1 16979362
    rencistka
    Hello ! I have recently had Cyfrowy Polsat. I am asking for a hint on how to record series, it is because series reruns are recorded, so maybe I'm doing something wrong? I record by record episodes. I have an EVOBOX PVR decoder
    arekopo
    Help: 8
    Rate: 41
    It's best to go to Polsat Cyfrowy and ask there, the instructions do not show anything :) maybe it is replaceable or you are actually doing something wrong
    Added after 23 [minutes]:
    I read that from November 30, 2017 there is new firmware for the EVOBOX PVR decoder, update it and see if it will be the same. The new firmware version for these decoders is: 2.2.1.
    How to update the software:
    Automatically on standby. In normal operation (turned on), the software will be downloaded in the background and the decoder will display a screen on the TV screen asking you to carry out the update process. Confirmation will start the update, while refusal to do so will execute the update when the decoder goes into standby mode. You can manually start and check for a new version by going to Settings -> Hardware settings -> Software update.
  • #3 17155412
    rencistka
    I replaced the set-top box with a new one that can also be replaced (records episodes of series but omits some)
