EVOBOX PVR Decoder: 0% Power and Quality on Sat1 and Sat2 Inputs After Switching from NC+
pszemkowsky 31461 7
  • #1 17754092
    pszemkowsky
    Hello, I have such a problem. Well, my contract with nc+ ended and I moved to Cyfrowy Polsat. Today, the courier delivered me the EVOBOX PVR decoder, after connecting it, the sat1 and sat2 inputs have 0% power and quality. I checked on an old decoder with nc+, everything is fine there, 100% strength and 80-90% quality.
    So the question is why can this happen?
    Regards.
  • #2 17754126
    Pan.Kropa
    Help: 252
    Rate: 1178
    Either the decoder is damaged or something in the converter settings in the Menu. What converter do you have?
  • #3 17754131
    rnb_bolii
    Help: 635
    Rate: 1177
    Hello. What installation? Do you have two converters (strabismus)? Is it in a block? Then the DiSEqC settings in the decoder.
  • #4 17754253
    LeDy
    Help: 1992
    Rate: 2942
    Surely in the settings for the converter you need to go through the procedure.
    Do you have a single converter and the decoder is set to Unicable?
  • #5 17754512
    andpol 33
    Help: 513
    Rate: 1146
    By default, the Evobox is set to Inverto unicable. You need to switch to a regular converter, 1 or 2 inputs.
  • #6 17754771
    Lamare
    Help: 5
    Rate: 17
    After entering the menu, you need to change the antenna settings a bit. I assume that the old sat antenna converter was a universal or so-called monoblock. Then in the menu, first, set the way you connected the antenna cable - SAT1 (LNB1) or SAT2 (LNB2). The LNB type cannot be SCR(unicable), only single or universal and the satellite set as HotBird. Also check that there is not too much copper sticking out of the F-type connectors - it must be flush with the F-connector, not protruding. If this does not help, check the operation of the decoder at the nearest Cyfrowy Polsat point. I don't know if you own or lease, but they should replace if defective.
  • #7 17756764
    Lamare
    Help: 5
    Rate: 17
    And one more thing - on the old NC+ decoder, check in the antenna settings in the menu what installation (or single cable), what type of converter (probably universal) and whether it worked on DiSEq. I've seen such solutions for the Monoblock in the canopy. All these settings need to be transferred to the new Evobox.
  • #8 17757758
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Regards.
    Change in Evobox PVR in Settings / Antenna / Configuration / Converter type to Universal. After changing, disconnect and reconnect the decoder's power supply.
    Wait for reboot.
The user is experiencing 0% power and quality on the Sat1 and Sat2 inputs of their EVOBOX PVR decoder after switching from NC+ to Cyfrowy Polsat. Responses suggest potential issues with the decoder settings, specifically the converter type and DiSEqC configuration. Recommendations include checking the converter type in the settings, ensuring it is set to Universal, and verifying the connection of the antenna cable. Users are advised to compare settings from the old NC+ decoder and ensure proper installation of the LNB. If issues persist, testing the decoder at a Cyfrowy Polsat point is recommended.
