Evobox PVR Cyfrowy Polsat - The unicable inverto converter does not catch the si
Mr_Krzys 19026 10
  • #1 16501988
    Mr_Krzys
    Rate: 18
    The problem is that after connecting the Evobox decoder to the Unicable Quad 40mm LNB converter, 2 Legacy Ports (IDLB-QUDL42-UNI2L-OPP) does not catch any signal. The cable connected to the gold connector and SAT1 in the settings changed to this type of converter and still nothing, I note that after connecting two silver connectors to SAT1 and SAT2 and setting to the universal converter is the signal from SAT1 and SAT2 so he does not understand what the problem is. Damage to the converter and the decoder is gone since I have already exchanged both devices and I have just finished ideas so I hope that maybe I will get some help here.
  • #2 16502495
  • #3 16503068
    Mr_Krzys
    Rate: 18
    The signal is at SAT1 level signal strength 70% signal quality 62%, SAT2 signal strength 82% signal quality 62%.
  • #4 16503110
  • #5 16503117
    Mr_Krzys
    Rate: 18
    On the universal, of course they work, without any disturbances.
  • #6 16503410
  • #7 16503943
    Mr_Krzys
    Rate: 18
    According to which instruction?
  • #8 16504042
  • #9 16504870
    Mr_Krzys
    Rate: 18
    According to the installation instructions, there is a connection of the gold connector at the converter to the SAT1 input at the decoder and in the setting I chose the unicable converter so obviously I did it at the beginning which did not give any positive result about what I mentioned. Do not you think that if the procedure in accordance with the instructions worked then I would assume here a topic with a request for help?
  • #10 16505827
    netTv
    Level 32  
    Help: 193
    Rate: 579
    After changing the converter in the antenna configuration on IDLB-QUDL42-UNI2L, disconnect the decoder from the power supply and reconnect. Check even the decoder software version in Settings / Information / Conditional Access, should be 2.0.2.
  • #11 16505921
    Mr_Krzys
    Rate: 18
    Ok, I solved the problem myself, everyone told me that the SAT2 input is inactive and here I am asking, I connected the golden connector from the converter to SAT1 and converter B connector to SAT2 and guitar, I record from three channels I watch the fourth, as it should be.
    Subject to be closed.
    Moderated By telesat1:
    Nonsense.
    3.1.11. Do not send messages that do not contribute to the discussion. They are misleading, they are dangerous or they do not solve the user's problem.
✨ The discussion revolves around issues faced by a user connecting an Evobox decoder to a Unicable Quad 40mm LNB converter (IDLB-QUDL42-UNI2L-OPP). Initially, the user reported no signal reception when using the Legacy Ports, despite having signal strength readings of 70% and 82% on SAT1 and SAT2, respectively, when connected to a universal converter. Various responses suggested following installation instructions and checking the decoder's software version. Ultimately, the user resolved the issue by correctly connecting the gold connector from the converter to SAT1 and the B connector to SAT2, enabling simultaneous recording and viewing of channels.
