EVOBOX Cyfrowy Polsat - Setting a list of favorite programs in the EVOBOX decoder
Jacek-555 48540 43
How do I create, activate, and reorder a favorites channel list on an EVOBOX Polsat decoder?
Create the favorites list in TV Channels, then switch the decoder to that list; you can reorder channels only inside Favorites, not in the full All list. To add channels, press Menu twice, go to TV Channels, open Options, then List / Modify / Favorites and confirm the channels to add [#19991052] After the list exists, while watching live TV press the left arrow and then right to reach ALL, press OK, and select FAVORITES; the Favorites option appears only after at least one channel has been added [#19600679] To change channel order, first make sure you are actually in the Favorites list, then open Menu twice → TV Channels → Options → Actions → Order/Sequence, select a channel, move it to the desired position with the arrows or number keys, and confirm with OK [#19600679][#19991052] If Favorites disappears entirely on some Polsat Box 4K Lite units, it was reported as a software bug; a later software version (1/7/28) was released to restore proper Favorites support [#20329611]
  • Favorites list accessed via TV program button
    #1 19570770
    Jacek-555
    Rate: 19
    Two days ago I received new EVOBOX decoders (Lite and PVR). Okay - undo and recording option. But no one could tell me how to set the list of "favorites", i.e. your own order of programs. Five people from the hotline claimed that after pressing the "Menu" button on the remote control, the word "TV programs" will appear in the top selection list. They did not want to accept that there was no such position. Through testing, I found out that the desired state can be reached by pressing the "TV program" button on the remote control. A menu expands with the option to add to favorites. But here I am stuck again, because after adding my own list of programs, I don`t know how to set them to be displayed as default. Switching between the general Polsat list and favorites does not work (as was the case with older decoders). Again, neither the sales point knew about it (they suggested checking the manual, but there was nothing there), nor the hotline. Somehow I managed to do it. Only after some time I realized that (after setting the favorites list) I had to press the "TV program" button again and search for "watch" in the list. It`s up and running. I just don`t know yet how to smoothly manage the list so that all and favorites are displayed in two columns and you can make changes between them or change the order of stations in your favorites. If anyone knows, please give me some tips.
  • #2 19572253
    Marek Skubisz
    Rate: 11
    I got the Evobox PVR yesterday and after many attempts I reached the same result. It seems that it is not possible to swap or change the order of channels as in PVR7000. You probably need to make a list in the desired order on a piece of paper and in that order add channels to your favorite list, "jumping" through "all".
  • #3 19599775
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Press MENU twice => CHANNELS => OK => Options button
  • #4 19600359
    Marek Skubisz
    Rate: 11
    I don’t think we understand each other: it’s about setting a list of favorite channels and following this method, our options include: remove from favorites list. There is nothing about creating a new one or adding to favorites. At least for me. That’s why I created it (wanting to have the desired order of channels) in the way I provided above.
  • Reorder favorites by using channel transfer mode
    #5 19600679
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Already have a list of favorites and want to change the order of channels?
    First, you need to change the list of currently selected channels from ALL to FAVORITES.
    While watching a channel, press the left arrow and then the right arrow.
    Go to ALL, press OK and select FAVORITES from the list, then select a channel from the list and confirm with OK.
    Then press Menu twice on your remote control.
    Next, go to CHANNELS, press OK.
    Press OPTIONS on the remote control. A list of options will appear. Select ACTIONS and then SEQUENCE.
    Now you are in channel transfer mode. Select a channel with the arrows and press OK.
    Then use the arrows to move to the position in the list where you want to move the channel and press OK. (You can use the number buttons on the remote control to jump to an item in the list more quickly.)
    Confirm the operation by pressing OK again.
  • Complaint about missing channel order settings
    #6 19991026
    MICHAŁ6201
    Rate: 177
    It does not work!!!! Parents got this decoder. Worthless crap. How can you pay so much money for such crap and not be able to set the order of channels? Unthinkable. Nowadays, they push people with crap that has no settings. Someone came up with the idea that Polsat should be on channel 1 and that`s how it should be. I would never want it even for free. I advise against it if anyone is wondering whether to sign a contract with them.
  • #7 19991043
    tomaszlonski
    Help: 346
    Rate: 899
    But you can do so by creating your own Favorites list. You can`t change standard channels because that`s how the operator set it.
    There are instructions on how to create one on the operator`s website, just visit and do it.
  • Favorites list ordering is limited and unreliable
    #8 19991052
    netTv
    Level 32  
    Help: 193
    Rate: 579
    You press the Menu button twice.
    In the main menu of the decoder, use the arrow to navigate to TV CHANNELS and OK.
    Then on the remote control press OPTIONS further in the on-screen menu => List => Modify => Favorites
    Now press OK to mark the channels that are to be added to the list (a check mark will appear at the top of the window with the channel logo)
    Then, to finish adding, click the down arrow and Ok to confirm.
    This way you add channels to the Favorites list in the order they appear in the All list.
    Therefore, it is easier to arrange the order of channels in the Favorites list by adding from the action menu. Right arrow on live. ADD TO FAVORITES
    To edit the order of a single channel in the Favorites list, use the Options menu in the TV CHANNELS menu.
    First, select the Favorites list in the TV CHANNELS menu and go to the list to watch a given channel, then return to the TV CHANNELS menu.
    Then, from the OPTIONS menu, we select => ACTIONS => ORDER, clicking OK on the channel, select the channel to be moved and use the arrow to move it to the selected position (you can numerically select the position you want to go to), then press OK at the selected position and confirm with OK again.
    Added after 4 [minutes]:
    It works, you just need to read it carefully.
    To edit the order of channels in the Favorites list, you need to switch to the Favorites list.
    To do this, first select the Favorites list from the available lists, then select a channel from this list, and then confirm the channel selection from the OK list.
    Otherwise you remain in the All list where you cannot edit the channel order.
    Note: The Favorites channel list appears in the selectable list only if at least one channel is added to it.
  • #9 19991137
    MICHAŁ6201
    Rate: 177
    Unfortunately it doesn`t work. There is no option to change the channel number. I want to set e.g. tvp1 on channel 1
    After all, this should be the basic setting option. And I told my parents to stay away from Polsat. There are much better choices from the competition.
  • Favorites list required to sort EVOBOX channels
    #10 19991154
    tomaszlonski
    Help: 346
    Rate: 899
    Because there is no option to change the basic list until you create a list in Favorites and switch to it. You can sort channels there and move them as you wish.
    My friend wrote exactly how to do it.
    http://www.polsatbox.pl/nowy-soft/
    ps The easiest way is to buy not the operator`s decoder, but the Ci+ module and a receiver with Enigma2, where you can freely create your own program lists, the same is true in the TV where the module is used.
  • #11 19991157
    MICHAŁ6201
    Rate: 177
    I added it to my favorites list and it doesn`t help me because there is no option to change channel numbers there. I`ve been struggling with this crap since the morning
  • Ordering EVOBOX favorites via add and options menus
    #12 19991164
    tomaszlonski
    Help: 346
    Rate: 899
  • #13 19991170
    MICHAŁ6201
    Rate: 177
    I don`t understand this at all. Butter Butter.
  • Evobox channel management remains unfinished
    #14 19991235
    netTv
    Level 32  
    Help: 193
    Rate: 579
    In my free time I will make a video on YT - :)
    You don`t need to understand it, just take the remote control and follow it step by step.
    The description was made from practice.
    Evoboxes were also supposed to have a separate menu in the "Channel Management" Settings, but there were no allies to turn the project into code.
    What is currently visible is laziness on the part of ADB.
    Lack of good channel management is one of the unfinished elements of the Evobox PVR project.
    Fortunately, the project for the "old" CPT decoders from the HD family was entirely implemented in CP and there is a menu there, but also with some compromise due to the hardware limitations of the decoders.
  • #15 19991549
    pikarel
    Help: 410
    Rate: 1848
    MICHAŁ6201 wrote:
    (...) And I told my parents to avoid Polish TV stations. There are much better choices from the competition.
    Yes? Maybe in Orange? Here`s a list of your favorites to scratch around after every power outage. Each update of the list by the operator results in the same thing.
    Maybe in Canal+, where it`s similar?
    It is worth knowing the issue you are writing about.
  • #16 19991604
    netTv
    Level 32  
    Help: 193
    Rate: 579
    As promised, a video on how to manage user favorites and lists in the Evobox and Polsatbox 4k family decoders.
  • #17 19991801
    MICHAŁ6201
    Rate: 177
    Thank you very much. You are great Master :)
    This was exactly what I needed. Now everything is clear. It works as I wanted :)
  • #18 20026094
    ZENEK898
    Hello! I also had a problem with programming this decoder (I managed with the previous ones), but after watching the video it went smoothly. Thank you for the tips and video. Zenek
  • #19 20267252
    DarekL.
    I`m refreshing an old topic when it comes to the list of favorite channels. After creating such a list, each time after a power outage this list disappears and I have to create it again and my question is whether there is any way to prevent this list from disappearing.
  • #20 20267255
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Do you mean the Favorites list or another one you created?
    Which decoder is this?
  • #21 20267261
    DarekL.
    netTv wrote:
    The list disappears?
    If you have a Polsat decoder, check it, just turn off the power and the "favorites" list will have to be created again
  • #22 20267262
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Well, there are several Polsat decoders called Evobox, so which model and which software version?
    For example, I use the Evobox IP decoder and I have no problems with the favorites list, so I would like to ask for specifics.
  • Favorites list disappears after power off on D61BW
    #23 20267277
    DarekL.
    I have 3 decoders at home: 1 Polsat Box 4K and 2 Posat Box 4K Lite, and the same thing happens on all of them. The favorites list disappears when the power is turned off, you have to create the list again.
    model D61BW, the latest software available, if you have this model, unplug it for half an hour and see if the favorites list disappears
  • Memory corruption may be clearing favorites list
    #24 20267383
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Do you have the Polsat Box 4k (D61BW) decoder configured in satellite + Internet mode?
    Is the decoder connected to the Internet?
    How many channels ~ do you have in your Favorites list?
    What software version is visible in Settings / About / Conditional Access.
    I just tested it on my Polsat Box 4k decoder and everything works properly, software version 1.4.6.
    I added 6 channels to my Favorites list. I turned off the decoder using the remote control to standby (soft standby) and disconnected it from the power supply for an hour.
    After reconnecting the power supply, the Favorites list is complete and the decoder starts on the last watched channel in the last selected Favorites list.
    Maybe your decoder has memory corruption and that`s why it loses the list.
  • Question about disabling the recently watched list on startup
    #25 20293968
    KAROL19766
    Help: 5
    Rate: 37
    And I have another question: the beginning of the movie and, as you can see, the list: recently watched (every time for me) when I turn on the decoder, the damn thing shows up?!!! How to turn it off? There was peace for some time and then it happens again!!!
  • #26 20293980
    netTv
    Level 32  
    Help: 193
    Rate: 579
    Take a photo because I don`t really know what you`re talking about.
  • #27 20294014
    KAROL19766
    Help: 5
    Rate: 37
    What you have at the beginning of the movie, this menu, is what appears in my case every time I turn on the decoder, I turn on the decoder and this appears:
  • #28 20294087
    netTv
    Level 32  
    Help: 193
    Rate: 579
    You can`t do anything about it with this operator`s strategy. To quickly close this window, press Exit or Back on your remote control.
    This screen used to be blocked by disconnecting the decoder from the Internet.
  • #29 20294126
    KAROL19766
    Help: 5
    Rate: 37
    What nonsense, you were right, I didn`t think about it, turning off the Internet in the decoder eliminates the problem!!!
    A sick solution
The discussion concerns configuring and managing favorite channel lists on EVOBOX / Polsat Box decoders, especially Lite and PVR models. The main issue is that the decoder interface does not clearly expose channel management, and users initially cannot find how to create, switch to, or reorder favorites. Several methods are described: entering TV Channels from the menu, using Options, then Actions and Sequence/Order to move channels within a Favorites list; adding channels from the live TV context menu via Add to favorites; and switching the active channel list from All to Favorites. It is also noted that on some firmware versions the favorites list disappears after power loss or becomes inaccessible due to a software bug, requiring a firmware update or operator support. Later posts confirm that newer software restores correct favorites handling on some Polsat Box 4K Lite units.
TL;DR: Three of three reporting users (100 %) say firmware 1/7/28 stops Favorites from vanishing; “It works, you just need to read it carefully.” [Elektroda, netTv, 19991052][Elektroda, netTv, 20431898]
Why it matters: Correct setup lets you finally keep and reorder channels instead of fighting the default Polsat list.
• Current stable firmware: 1/7/28 for Polsat Box 4K Lite, serial ERDZ [Elektroda, 20431898] • Favorites list appears only after ≥1 channel is added [Elektroda, 19991052] • Menu path for re-ordering: Menu ×2 → TV Channels → Options → Actions → Sequence [Elektroda, 19600679] • Buggy build 1.4.6 could erase Favorites after power loss on D61BW units [Elektroda, 20267277] • Operator blocks edits to the default “All” list; only Favorites are editable [Elektroda, 19991154]
How do I add a channel to the Favorites list on EVOBOX/Polsat Box 4K?
  1. While watching the channel, press the right arrow; choose “Add to Favorites” and press OK.
  2. Or press Menu ×2 → TV Channels → Options → List → Modify → Favorites, then tick channels with OK. [Elektroda, netTv, 19991052]
How can I make Favorites the default list every time I switch channels?
Press the left arrow, move right to “All”, hit OK, select “Favorites”, confirm with OK. The decoder now browses Favorites until you change it again. [Elektroda, netTv, 19600679]
Can I reorder or renumber channels inside Favorites?
Yes. Switch to Favorites, then:
  1. Menu ×2 → TV Channels → Options → Actions → Sequence.
  2. Highlight a channel, press OK.
  3. Use arrows or number keys to move it; press OK twice to save. [Elektroda, netTv, 19600679]
Why can’t I move channels on the main “All” list?
Polsat locks the operator list; only user-created Favorites can be sorted. “You can’t change standard channels because that’s how the operator set it.” [Elektroda, tomaszlonski, 19991154]
My Favorites disappear after every power outage—what’s the workaround?
Update to firmware 1/7/28. Users on D61BW hardware reported the loss in build 1.4.6, but the January patch keeps lists intact after a one-hour unplug test. [Elektroda, 20267277][Elektroda, 20431898]
Which software version fixes the missing Favorites bug?
Firmware 1/7/28, released February 2023 for Polsat Box 4K Lite (ERDZ serial), resolves Favorites visibility and saves lists to non-volatile memory. [Elektroda, netTv, 20431898]
How many channels can I store in Favorites?
Typical capacity is 999 entries—the same as the full channel table in the user manual (Polsat Box 4K Lite Guide). Few users exceed even 50; one demo shows 6 channels saved. [Elektroda, netTv, 20267383]
The Favorites option vanished from my menu—what happened?
A December 2022 firmware pushed to some 4K Lite units hid Favorites. Polsat acknowledged the defect; a corrective patch rolled out in January 2023. Contact the hotline if the option remains missing. [Elektroda, 20329611][Elektroda, 20341066]
Can I stop the “Recently Watched” window that pops up on start-up?
Disconnect the decoder from the internet or press Exit/Back each time. The overlay is tied to the operator’s online recommendation service and cannot be disabled in settings. [Elektroda, netTv, 20294087]
Is complete channel renumbering possible on EVOBOX?
No. Only Favorites order changes. If you need full numbering control, use a CI+ module with an Enigma2 receiver. [Elektroda, tomaszlonski, 19991154]
Edge case: lists vanish after just 15 seconds unplugged—real or myth?
Real for some pre-patch Polsat Box 4K units; user noofin lost all lists after a 15-second outage. Firmware 1/7/28 eliminates this failure. [Elektroda, noofin, 20754940][Elektroda, 20431898]
Quick 3-step re-ordering cheat-sheet?
  1. Switch to Favorites list (left → right arrows, pick Favorites).
  2. Menu ×2 → TV Channels → Options → Actions → Sequence.
  3. Select channel, press OK, move with arrows/number, press OK again to lock. [Elektroda, netTv, 19600679]
