Transferring a video from the nbox recorder disk to the computer disk
klabar 11676 7
  • Archiving recordings from the ITI-3740 NX hard drive
    #1 16980532
    klabar
    Good day.
    I do not know if I am writing in the good section but I have a question: is it possible to rip movies and programs recorded on the NC + decoder disk to the computer disk at home to archive some programs? I am asking because I have already lost 3 times priceless for me programs from the 60's broadcasted on TV by some miracle, because the decoder / tuner from enki broke. Replacement and of course a blank disk. Theoretically, the disc could be removed, ripped and reinserted, but one screw was stuck with a warranty sticker. Is there any way to do this? The tuner I have has a 500GB hard drive, the tuner model is ITI-3740 NX.
  • #2 16980593
    jalop
    Help: 40
    Rate: 204
    Gearing the disk won't help.
    Only catching the recording "on the fly", eg by a TV card.
  • #3 16981041
  • #4 16981189
    klabar
    mihal2002 wrote:
    klabar wrote:
    Is there any way to do that
    This is how you turn on the material saved on the disk and save it on a DVD Recorder with HDD connected to the decoder.
    there is no place, the inputs to connect a dvd recorder with hdd (I have one) there is only a usb port and hdmi and an optical audio output. You have to keep trying ... :(
  • #5 16981197
    jalop
    Help: 40
    Rate: 204
    Enter the model. HMDI from tuner to DVD and from this device HDMI to TV or SCART.
  • #6 16981238
  • #7 16982924
    klabar
    The recorder is old as hell, lg I don't have a model because it's hidden in my father's closet. But, in fact, there is scart in the decoder and scart in the recorder. So from the tuner to the recorder through scart and from the recorder with some TV cable and that's enough?
  • #8 16982948
    jalop
    Help: 40
    Rate: 204
    If it's old it only has scart, so you need two of them.
The discussion revolves around the possibility of transferring recorded content from an NC+ decoder (model ITI-3740 NX) to a computer for archiving purposes. The user expresses concern over losing valuable programs due to hardware failures. Responses suggest that direct ripping from the decoder's hard drive is not feasible. Instead, alternatives include using a DVD recorder connected via SCART or HDMI to capture the content "on the fly." The user notes limitations in their setup, including only having USB and HDMI ports available on the decoder. The conversation highlights the need for compatible connections between the devices to facilitate the transfer.
