Connecting a decoder and a computer - How to connect a decoder to capture HD
adamsonm 9822 7
  • #1 16535564
    adamsonm
    I have a question, it's time to switch from old good cable TV to digital TV. I have at home 1 TV (parents) and in my room a computer with a TV card. Unfortunately, the image on the monitor is tragic, because the cable gives too low resolution. On days, we change cable TV to digital in the estate. The cable will go to the TV straight from the set-top box (I skip multiroom aspects, because I don't know how at my estate solve this problem). However, what if I wanted to connect the decoder to the computer to continue watching TV on the computer as it is now? I warn you that I am not interested in direct connections to the monitor, because I use the computer many times and watch TV in the window next to it, or play a music station. To capture an image in HD, I have to use HDMI, right? So what to buy so that this image on the computer was in this HD, and not like with the help of SCART, or is there any decoder that will release after Composite 1080p? Can it be done in a small budget or are there only AVerTV Capture HD cards for over PLN 400?
    PS: my current card is Winfast tv2000 xp expert, but I expect it is already a turn and it will not be suitable for a digital camera ;)
  • #3 16535626
    adamsonm
    So how do you connect a decoder to this tuner?
  • #4 16535635
    Kasek21
    Help: 4981
    Rate: 3547
    You will not connect a new decoder to your TV Tuner.
  • #5 16535638
    adamsonm
    I meant the tuner recommended by @ wies333 , but it only has an antenna input, if I only wanted to download free channels.
    EDIT:
    https://www.ebay.com/p/Pci-e-HDMI-HDCP-Decode...e-Capture-Card-for-Ps3-4-Xbox-Wii/1639930771? iid = 152584876260
    something like that would solve my problem?
    EDIT 2:
    television works with the help of a CI card, so is there any cheap solution to this, in addition to (again) cards for over PLN 300?
    EDIT 3:
    One thing is giving me peace all the time. On the plot I have the cheapest USB DVB-T tuner and plug in the old antenna to collect free channels. It catches me all and I think it is HD quality because on a 1366x768 laptop resolution everything looks nice and without pixels. Or is there somehow a decoder connected to such a tuner via an antenna cable?
    something like this:
    http://www.cyfrowydoradca.pl/poradniki/polaczenia/telewizor-dekoder-modulator-rf.html
    I would use a decoder that has an antenna output:
    http://www.komputronik.pl/product/392912/wypr...3-combo-full-hd-po-naprawie-gwarancyjnej.html
    and then connected with an antenna cable to the USB tuner. And then, according to the above article, one channel should have a signal from the decoder. Can he do it without going to SD?
    Sorry for so many questions, but in terms of television and TV standards I am mega green, and if I already have HD TV at home I would like to use it, but without spending PLN 400 :(
  • #6 16537353
    Kasek21
    Help: 4981
    Rate: 3547
    ... and two receivers will work on one decoder without the multiroom option?
  • #7 16537408
    adamsonm
    no. the receiver at his parents' decoder with his card, me on my own.
    in addition, 720p is enough for me, because I wouldn't even be able to use 1080p. Currently I am looking at used Ariva 220 and some grabber by component. Can I pull 720p then?
  • #8 19970649
    mechanik34
    I read all the combinations with decoders and I have this thought: is it possible to create a universal decoder that will be able to switch inside and select the frequency range we will meet when we meet to avoid buying and dealing with problems. Maybe someone tried to make their own?
The discussion revolves around connecting a digital TV decoder to a computer for HD viewing. The user seeks to transition from cable TV to digital, expressing dissatisfaction with the current low-resolution image on their monitor. They inquire about using HDMI for HD capture and whether a specific tuner or decoder could facilitate this connection. Responses indicate that connecting a new decoder directly to a TV tuner may not be feasible, and alternatives such as USB DVB-T tuners are suggested. The user considers using a CI card and explores options for capturing 720p resolution. There is also a mention of the potential for a universal decoder to simplify connections and frequency selection.
