How to transfer recordings from Cyfrowy Polsat Sagemcom 88-320 HDD to PC?
djmartin1981 79437 11
How can I transfer recordings from a Cyfrowy Polsat Sagemcom 88-320 HDD decoder to my laptop and convert them to AVI?
You cannot directly copy recordings from this decoder’s HDD to a PC: the recordings/data are encrypted, and even if the disk is detected, the computer cannot read the content [#9077600][#9269263][#11026195] The drive is handled for the decoder, not for Windows, so connecting it to a laptop will not let you access the files or choose a format to convert from [#10980872][#11026195] In practice, the only workaround mentioned is to play the decoder output into a standalone DVD recorder and capture it that way [#12002370]
  • #1 9077056
    djmartin1981
    Hello. I just bought a polsatu sagemcom 88-320 decoder with a hard disk. How can I transfer recordings from the decoder disk to my laptop? What is the recording format and what is it to convert to, for example, AVI. I connected the disk to the paw, it detected it but it cannot be entered. I am green in this, please give a fairly accurate answer. Regards and thank you.
  • #2 9077600
  • #3 9242821
    djmartin1981
    When I hook up the recorder and turn it on, I have "ants" on the screen, hehehe, and when I turn it off, an image appears. As if the decoder was allergic to the recorder.
  • #4 9243281
  • #5 9268812
    die4
    I attach to the topics because it bothers me a lot, how to rip files from DVR to computer or something else! Do I need to upgrade to a hard drive?
  • #6 9269263
  • #7 10980762
    Grubskee
    Help: 8
    Rate: 54
    The disk is not encrypted or locked in any way, just its firmware is written not for the PC but for the Decoder. Only the replacement of electronics or firmware that cannot be found on the Internet can help, there may be tools that allow you to rip the firmware (from a normal disk) and upload it to this Hitachi, but I was looking and I could not find it, and when programs are paid, e.g. AFF Repair Station. I have this information from the website at HGST.com
  • #8 10980872
    egon42
    Level 37  
    Help: 358
    Rate: 825
    Buddy, it's not about disk encryption, but that the data on the disk itself is encrypted and if you even moved it to another disk, it sneezes anyway.
  • #9 11025810
    lukaszczecin
    It seems to me that it is rather not encryption, but the disk partition is not supported by the computer. I have a TV decoder for katra and a USB disk and when I connect the recording disk to the computer, I immediately want to format it because it writes that the sest is not the correct partition
  • #10 11026195
    egon42
    Level 37  
    Help: 358
    Rate: 825
    lukaszczecin The disk partition is not supported by the computer, so one and two are still encrypted data on the disk, even if you somehow transfer them to the computer, you won't see anything anyway.
  • #11 12002370
    oksip
    Rate: 9
    Hello. I rip off the decoder disc using a Sony Rekorder desktop recorder
  • #12 12002601
    egon42
    Level 37  
    Help: 358
    Rate: 825
    Buddy, you could always play it like that, already on the 1st post, my colleague mihal2002 wrote and what kind of refreshing old chops did your colleague not read?
The discussion revolves around the challenges of transferring recordings from a Cyfrowy Polsat Sagemcom 88-320 decoder's hard disk to a laptop. Users highlight that the data on the disk is encrypted, making direct access impossible when connected to a computer. Some suggest that the disk's firmware is not compatible with PC systems, and even if the disk is detected, the data remains inaccessible. A few users mention using a DVD recorder as a potential workaround, but the effectiveness of this method is questioned. Overall, the consensus is that without specialized tools or firmware modifications, transferring recordings is highly problematic.
