Hotpoint Ariston WMD 722 washing machine - noisy drum operation.
Darek darecki 8052 5
  • #1 16983963
    Darek darecki
    The Hotpoint Ariston washing machine began to run loud, that is, the drum. Is that a bearing, some object inside, I don't know. The drum seems to be walking sideways, and it is tightened.
    Maybe the inside bearing is dead, because the back one seems good. I do not know. Give me some advice, and I'm a little afraid to spin the whole thing, because I'm afraid that I will not turn. If I had a guest in Targówek who would do it, of course, not for free, but also for the cost of a new washing machine, thank you in advance. Darek
    • VID_20180123_231014.mp4 (39.47 MB) You must be logged in to download this attachment.
    • VID_20180123_230917.mp4 (43.88 MB) You must be logged in to download this attachment.
    • VID_20180120_134930.mp4 (31.76 MB) You must be logged in to download this attachment.
  • #2 16984339
    Piotr2608
    Help: 851
    Rate: 4487
    Darek darecki wrote:
    I'm a bit afraid to spin the whole thing up because I'm afraid it won't turn.
    Call a specialist who will not be afraid to start it.
    I do not know.
    So you don't know anything
    Start by checking the drum's lateral and longitudinal play. When opening the washing machine door, grab the drum with your hands - up, down, front and back. The drum has no play, no knocking.
    If you feel any looseness and hear clicking, you have bearings to replace - it's for posterity.
    You can hear knocks in your washing machine, you can see slack, so you will not need to replace the bearings.
    ZimTech Piotr Zimny
  • #3 16984473
    Darek darecki
    Thank you. Well, I have bearings to replace.
    The whole washing machine to unscrew and remove the bearings with a burner as I watched. Then I'm calling someone. Regards and thank you.
  • #4 16991159
  • #5 18197002
    life27
    Rate: 95
    I have a similar problem with the WMG722PL model, I started it and something breaks down inside the drum, it pays to buy a new drum for 6 hundred + probably 2-3 hundred for a specialist to come and replace or take a new washing machine?
  • #6 18197260
    Kenworth 18
    Help: 2442
    Rate: 3749
    If you have such a fondness for your washing machine is invest, but perhaps more profitable, for example, are: https://mediamarkt.pl/agd/pralka-bosch-wae202...DZ9NrglzuQ27p5Lnos2S-F9cYkXWOjMjtebfaNyxAaAuL -EALw_wcB
    And this washing machine already has a washing assembly that is disassembled and the bearings can be replaced: https://north.pl/czesci-do-pralek/czesci-bosc...epl-pralki-bosch,940,WAE2026EPL,m3097785.html
