Bosch Classixx 5 WAA20261EN / 16: Identifying Correct Bearings and Simmering-Sealant for Noise Issue
pritchard 9306 5
  • Request for bearing and seal specifications
    #1 16461458
    pritchard
    Rate: 12
    Hello all,
    In my nearly 6-year-old washing machine, noise started to make noise, especially when spinning. I did not feel any slack on the cross or the axis, just hear it is louder than before.
    I have a question for those who are familiar with the topic, what are the bearings specifically in this washing machine and what simmerring - sealant? Before dismantling this non-recoverable, unfortunate washing group, I would like to know if I will be able to buy such bearings.
    Below is a video showing how it works. Unfortunately, I did not make a film from the work of the drum itself (the drive belt was removed).
    [Film: 3d5918275d] https://filmy.elektroda.pl/24_1494175475.mp4 [/ film: 3d5918275d]
  • #2 16468336
    pritchard
    Rate: 12
    Raises.
    Please help. Does nobody know what bearings and sealants are in this washing machine?
  • #3 16468924
    mirofalcon
    Help: 72
    Rate: 360
    In this washing machine there is a glued washing unit, at this washing machine the manufacturer does not give the size of the bearings, as the replacement part is the whole washing unit, part code: 00244196
  • #4 16469221
    pritchard
    Rate: 12
    I know there is a glued bathtub. Otherwise, I would not ask such a question :-) The whole washing team, in the store with spare parts, costs about 700 PLN. Some paranoia.
  • #5 16494191
    pritchard
    Rate: 12
    I will write how things are. Because I did not have room for replacing the bearings myself, I decided to send the entire washing team to Mr. Rafał from Krosno (advertisement on OLX). The courier picked up the package from me on Monday (15.05). The price of courier shipment in that direction is less than PLN 25. It turned out that the teardrop is ok, so the sleeve under the sealant, two bearings and the sealer itself was mentioned, I paid PLN 225. I had the package on Friday (19.05). So, for a total of around PLN 250, I have a washing team repaired. The washing machine works like new. By the way, I descaled the heater and all the rubber snakes, because a lot of stone has accumulated there. Tomorrow I will try to put in videos showing how the washing team worked before and after the repair. Greetings.
  • #6 17795833
    knedel
    Maybe I did not have enough - the cross was repaired just before Mr Rafał's leave - but Mr Rafał from Krosno made me poorly off the cross. The drum worked centrically before the crusader failure. I sent the whole team washing with a courier, in Krosno the housing was cut, the cross was repaired, glued and I received the parcel back. I put the washing machine and a slight disappointment - the drum has a beating more than 400 revolutions. So I exchanged two drum dampers - 8 year old washing machine - unfortunately it did not help. I do not want to disassemble the entire washing machine, pack the washing unit, send etc. Bosch washing machine WAA2027JPL.
    In conclusion - I would not undertake such a repair again.
