Sony KDL 46Z4500 Stops and Flashes 9 Times After T-Con Board 1-878-090-21 Replacement
Jim62 3408 1
  • #1 16988090
    Jim62
    hello
    i have a kdl 46z4500 and i had a problem of vertical bar appeared on the left 1/8 of the screen as the link .
    https://www.elektroda.pl/rtvforum/topic3374440.html
    i replaced the t-con card 1-878-090-21 a 1562061a by another card a1562060a .
    Now the tv starts 0.5 second and stops with 9 flashes of the red light at the bottom .
    Have you an idea ? Thks
  • #2 17054753
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    Hi
    Looks like this is HFR (high frame rate) Error [RED 9 times blink]
    This indicates HFR Communication error.
    Mouton (IC5505) micro (on BGC board) is communicating with T-con board.
    Replace BGC board or LVDS harness (between BGC board and T-con board). Also I would focus on those connectors where harness is snapped if they are damaged or dirty.
    Regards
