Struggling with Firmware Update on Huawei Ascend G620s-L01: Errors and Possible Fixes
acorp 5610 3
  • #1 16988771
    acorp
    The phone stutters, I did a factory reset, but nothing helps.
    Currently I have uploaded the original Polkomtel branded soft.
    I wanted to upload the original soft from Huawei:
    G620S-L01 V100R001C22B243CUSTC22D00128 Polkomtel29
    G620S-L0120V100R001C150B248CUSTPOLC150D005
    I uploaded to SD card, I hold Vol +, Vol-, Power but the attempt fails:
    oemsbl version list check error
    Error: update.app is a invalid package
    Error: Sd card update failure.Sd card update abort!
    In turn, if I want to enter Fastboot & Rescue (Vol- and Power), I have PHONE Locked.
    I don't need to unlock the bootloader to upload the original soft?
    Can anything be done about it?
  • #3 17414958
    isatoria
    As far as I know, this message appears when we want to downgrade our android.
    If we use the dload method, our UPDATE.APP file should be the same or a newer version.
  • #4 20254988
    arturmarek1
    Rate: 15
    I have the same problem or did it
    Would you like to upload the software? If so, how?
