Huawei Ascend G620S-L01 Soft Brick: Stuck on Logo, Factory Reset & Fastboot Rescue Mode Fail
Rossoneri92 8313 6
  • #1 16972828
    Rossoneri92
    Hello. I have the Huawei model as above, the phone worked until suddenly when it turned off, it can not be turned on, it stands on the huawei inscription and goes no further. I didn't upload anything. I tried to resurrect the phone with power and vol + to do wipe data / factory reset, but unfortunately it didn't work, uploading a new software won't do anything either, because I can't do it because unfortunately fastboot & rescue mode is blocked, I write phone locked. Does anyone know what I can do in this situation? will unfortunately only the service will bring your phone back to life? Thank you very much for your answer.
  • #3 16974676
    Rossoneri92
    Yes, everything is beautiful, but how do I unlock the bootloader? You need this code, the huawei website gives the phone model, imei, no. serial and product id, but to give the latter you need to enter the combinations * # * # 1357946 # * # * but how to do it on a dead phone where only the huawei logo is displayed what? Here is the dog buried, and if I do so on sd to dload I add this update, unfortunately it always ends in the same way that card sd invalid name etc. etc.
  • #4 16974744
    nutergsm
    Help: 1034
    Rate: 1665
    Download the firmware from the second link and upload the program.
  • #5 16985418
    Rossoneri92
    Unfortunately, without unlocking the bootloader I will not do anything to do it, enter imei, S / N and product id only with this id there is a problem, how do I read the code as there is a need to enter the code in the phone it will display, but if I have it on the frozen phone log done, anyone had such a problem?
  • #6 16985615
    nutergsm
    Help: 1034
    Rate: 1665
    The factory firmware should upload without the need to unlock the bootloader.
  • #7 17413812
    isatoria
    Good morning,
    I also have Huawei Ascend G620S-L01-V100R001C00B242SP02. When I wanted to start it some time ago after quite a long time of inactivity, the phone did not want to charge and instead the screen showed a silver battery with a red lightning, plus the diode was flashing red (correct charging would be similar, although the diode should not flash and on the screen the battery charging animation was visible).
    I changed the battery and got rid of the problem but the phone is still unable to start properly, after starting or connecting the charger it goes into FASTBOOT & RESCUE MODE, as in the photo below:
    I tried to download various UPDATE.APP, which I then uploaded to a microSD card formatted earlier in the FAT32 system, somehow I even managed to run the recovery, unfortunately it was impossible to install the file from the card, because there was an error (I do not remember exactly, there is something missing)
    I would like to try to fix the phone using the link provided in the post above, unfortunately I do not know the software well enough to know what to do, can anyone describe step by step how to upload the official soft?
    Regards.
The Huawei Ascend G620S-L01 is experiencing a soft brick issue, remaining stuck on the Huawei logo and failing to boot. Users have attempted factory resets and fastboot mode without success, often encountering a locked bootloader that prevents further recovery efforts. Some users suggest downloading specific firmware and using upload programs, while others highlight the necessity of unlocking the bootloader, which requires accessing the device's IMEI and product ID. Issues with SD card formatting and invalid file names have also been reported during recovery attempts. One user resolved a charging issue by replacing the battery but still faced booting problems. Overall, the consensus indicates that professional service may be required for complete recovery.
