Huawei y625-u51 Firmware Issue: Stuck on Logo, Error 7, Seeking Working Firmware Solution
wojsie8148 4734 5
  • #1 16435658
    wojsie8148
    Hello, I got a model for repair, as in the topic with damaged firmware, all the time on the logo. I tried to upload the latest soft via the memory card, but error 7 pops up, I did not find a newer software than the one provided by the manufacturer. I add a screenshot after trying to upload the software, maybe someone of you had a similar case and maybe you have a firmware that works, I will add that the tests are like the hardware was ok and I also wipe it
    Huawei y625-u51 Firmware Issue: Stuck on Logo, Error 7, Seeking Working Firmware Solution Huawei y625-u51 Firmware Issue: Stuck on Logo, Error 7, Seeking Working Firmware Solution
  • #2 16481474
    kawasz1982
    Rate: 15
    Buddy, did you handle it? I have a similar case :(
  • #3 16482067
    misiekelk
    Help: 47
    Rate: 121
    Partitions in emmc are crashing. Most of Huawei with qualks to grasp. I have not yet had pcs that have not got up. I load boot or flash after isp or shorting tp or cmd to mass. Then I am looking for a service flash in dc unloker or furius pack 7. You can also upload a boot to Huawei with a service program and then use a fastboot flash or card. And repairing the numbers, although now the softs are making a copy of nvm.
  • #4 16482433
    xbox-serwis.eu
    Help: 52
    Rate: 210
    1. Undress tel
    2. Make a jumper
    3. Connect to the PC, in the device manager, in the Ports section, the device should be:
    4. You are downloading Huiye Download Tool:
    http://www.muzisoft.com/soft/178403.html
    After the flash, the phone should stand up.
    Greetings
    XBOX-SERWIS.EU
    Karmelicka 15, Kraków, 31-131 | Company Website: http://www.xbox-serwis.eu
  • #5 16488848
    wojsie8148
    I uploaded the firmware from y625-u32 and then flashed the firmware for u 51
  • Qualcomm 9008 mode and Sahara flash error
    #6 16774237
    krecik10
    Rate: 56
    Buddy wojsie8148, you can provide links to a proven software that went
    Added after 19 [hours] 27 [minutes]:
    For me, the problem is that the phone does not start at all in the device manager, it shows up as Qualcomm HS-USB QDLoader 9008, I made a jumper according to the photo when trying to flash it shows the error failed to send command from the host the device and Fail on a red background = QLIB_QPHONEMS-Sahara_FlashProgrammer, I'm uploading Y625-U32V100R001C479B106Encryption.Unsuccessful.Error.Fix, and I have Y625-U51, it may be the fault of emmc released.
