[Solved] Insufficient Laptop Power Supply? Fujitsu 20V/3.25A vs ASUS 19V/3.15A Compatibility & Risks
fuitsu staszek 12870 12
Can I safely power a Fujitsu laptop that needs 20V/3.25A with an ASUS 19V/3.15A adapter, and could it damage the laptop if the battery is removed?
A 19V/3.15A adapter is generally reported to work on a laptop rated for 20V/3.25A without damaging it, and several users said that mixing 19V and 20V laptop power supplies caused no problems in practice [#16989420][#16989427] One reply notes that with a battery installed it may simply charge more slowly, but in your case the battery is removed so that part does not apply [#16989420] Another reply warns that the original, correct power supply is still preferable because mismatched adapters can cause complications over time [#16989559]
  • #1 16989399
    fuitsu staszek
    Hello, I have purchased a fuitsu laptop that requires a 20V / 3.25A power supply.
    However, I couldn't get a power supply so I connected an ASUS 19v / 3.15A power supply.
    I have a question if something can be damaged in the laptop (the batteries were removed).
  • #2 16989420
    dr.master
    Help: 518
    Rate: 927
    It will not damage, at most it will charge the battery slower.
    It is generally accepted that the current should not be lower than the rated current, but I have been using such power supplies for years ...
  • #3 16989427
    gimak
    Help: 614
    Rate: 1678
    Rather, nothing should happen. I, too, have been doing such replacements of power supplies (19 and 20 V) for a long time and nothing happened to the computers or power supplies.
  • #4 16989433
  • #5 16989531
    fuitsu staszek
    So far I have not noticed any disturbing symptoms, but maybe someone else will add some comments.
    I took out the battery because it doesn't work anyway, so why should you "charge" and additionally load the power supply.
    PS. The power supply does not heat up above the norm.
  • #6 16989541
  • #7 16989559
    safbot1st
    Help: 2719
    Rate: 1585
    Damage, nothing will be damaged, but I will present a different opinion.
    The power supply should be original, as complications may arise over time.
    I have 2 power supplies with the same parameters 19V / 3.42A ASUS and Toshiba.
    ASUS on the Toshiba power supply stops turning on after some time ... ;)
  • #8 16989584
  • #9 16989590
    safbot1st
    Help: 2719
    Rate: 1585
    There is nothing to develop ... You have to use original power supplies and that's it.
  • #10 16989767
    fuitsu staszek
    It cannot be ruled out that this is a power supply problem. After all, the Asus current does not differ from the Toshiba brand current.
  • #11 17005282
    carrot
    Moderator of Cars
    Help: 1315
    Rate: 3603
    Dell has an additional pin in its power supplies (plugs), on which there is a signal identifying the power supply, if you connect a weaker than required one, it will block the processor multiplier and will work with a lower clock speed
  • #12 17034965
    fuitsu staszek
    Since the battery has 11V and the laptop is to work, the more so on a 19V power supply.
    I tested 2 power supplies and nothing bad is happening.
  • #13 17038881
    fuitsu staszek
    power supply does not matter (not stated)
The discussion centers around the compatibility and risks of using an ASUS 19V/3.15A power supply with a Fujitsu laptop that requires a 20V/3.25A power supply. Users generally agree that using the lower voltage power supply should not cause damage to the laptop, although it may result in slower charging. Some participants have used similar power supplies without issues, while others caution that using non-original power supplies could lead to complications over time. The conversation also touches on the importance of using original power supplies for optimal performance and reliability.
TL;DR: A 19V vs 20V swap is a 5% voltage difference; one expert noted, "It will not damage." [Elektroda, dr.master, post #16989420] Why it matters: This FAQ helps laptop owners decide if a near‑spec power adapter is safe, what risks exist, and how to test quickly.
Can I power a 20V/3.25A Fujitsu with a 19V/3.15A ASUS adapter?
Yes, several users report 19–20V swaps working without damage in practice. The 1V gap equals a 5% difference. Ensure the adapter’s current is not below the laptop’s need; otherwise performance or charging may be limited. Start the laptop and observe for stability and normal adapter temperature. “It will not damage,” as one expert noted from long‑term use. [Elektroda, dr.master, post #16989420]
Will using a lower‑amp adapter harm my laptop?
Harm is unlikely, but the adapter may run at its limit and charging can slow or pause. The key rule is simple: the adapter’s current rating should not be lower than the laptop’s requirement. If it is lower, the system may throttle tasks or refuse to charge while running. [Elektroda, dr.master, post #16989420]
Is it safe to run the laptop without a battery on a substitute adapter?
Yes. A forum expert uses laptops without batteries on bench supplies and even car power, and reports stable operation. Removing a dead battery also reduces load on the adapter. Watch for clean boot, stable screen brightness, and no unexpected shutdowns. [Elektroda, 767667, post #16989433]
Why do some brand mixes (ASUS ↔ Toshiba) behave oddly even with matching specs?
Physical specs can match, yet firmware handshakes or tolerances differ. One user saw an ASUS laptop stop turning on when powered from a Toshiba 19V/3.42A supply after some time. That suggests brand‑specific signaling or protection behavior. Using the original adapter can avoid such quirks. [Elektroda, safbot1st, post #16989559]
What happens on Dell laptops if the adapter is underpowered or unrecognized?
Many Dell models identify the adapter via a center ID pin. If power is weak or the ID fails, the BIOS can block proper charging and reduce CPU multipliers, cutting performance to protect hardware. [Elektroda, carrot, post #17005282]
Will performance throttle with an insufficient adapter on non‑Dell systems?
Yes, systems can still limit performance when draw exceeds the adapter’s capability. Symptoms include lower CPU clocks, dimmed display, or disabled charging while on AC. These protections resemble Dell’s behavior noted by users. [Elektroda, carrot, post #17005282]
What signs show my 19V adapter is struggling on a 20V laptop?
Look for coil whine, screen dimming under load, charging that pauses while working, or a hot power brick. In the thread, the user noted the adapter did not heat above normal during successful use—overheating would be a red flag. [Elektroda, fuitsu staszek, post #16989531]
Quick 3‑step check: is my substitute adapter a go/no‑go?
  1. Match voltage within about 1V (e.g., 19V vs 20V).
  2. Ensure adapter current rating is not lower than the laptop’s rating.
  3. Test boot and light load; confirm normal temps and no charging errors.
    “Current should not be lower than the rated current.” [Elektroda, dr.master, post #16989420]
Are there long‑term risks to using non‑original adapters?
Some users caution that complications can appear over time despite matching specs. One expert’s stance: “You have to use original power supplies and that’s it.” If stability matters, prefer the OEM adapter for firmware compatibility and signaling. [Elektroda, safbot1st, post #16989590]
Does an 11V battery spec imply a 19V adapter will always work?
No. One user observed normal operation with an 11V battery system and 19V adapter, but that does not generalize. Internal regulators vary. Always verify behavior on your model before relying on the setup. [Elektroda, fuitsu staszek, post #17034965]
What is an adapter ID (barrel‑pin) signal?
It’s a data line in some plugs that identifies adapter wattage and authenticity. On many Dells, the laptop reads this pin at boot. If the signal indicates low wattage or fails, charging and CPU speed can be limited. [Elektroda, carrot, post #17005282]
Can a universal or car (cigarette‑lighter) adapter run a laptop safely?
Yes, if voltage is correct and current is adequate. An expert reported powering laptops for diagnostics from vehicle power without issues. Use quality hardware and monitor for stability. Avoid cheap, unregulated adapters. [Elektroda, 767667, post #16989433]
Is the 19V→20V difference really small enough to ignore?
It’s a 5% difference. Users report years of success swapping 19V and 20V laptop supplies without damage. Still, confirm plug size and polarity, and verify normal thermals. [Elektroda, gimak, post #16989427]
Will my adapter charge slower if it’s slightly weaker than required?
Yes. Charging speed drops when the adapter cannot supply full current while the laptop is running. Some systems may prioritize powering the laptop and pause battery charging until load decreases. [Elektroda, dr.master, post #16989420]
Edge case: why would an ASUS laptop stop turning on with a third‑party supply later on?
It can be a protection trigger or tolerance drift. One report showed initial success, then later refusal with a Toshiba adapter. Firmware checks or connector wear can cause intermittent recognition. Use the OEM unit to rule this out. [Elektroda, safbot1st, post #16989559]
What’s the practical takeaway from the thread’s testing?
The OP tested two non‑original supplies and saw no issues or abnormal heat. That suggests many 19V supplies can run 20V‑rated laptops, if current suffices and signaling is compatible. Validate on your device. [Elektroda, fuitsu staszek, post #17034965]
