How to start Fujitsu Siemens DPS-800GB-3 A – no +12V, green LED blinking?
nilder 24390 2
  • #1 12986367
    nilder
    Help: 5
    Rate: 30
    I have a Fujitsu DPS-800GB-3 A power supply and I have a problem with starting it. I tried the method from the topic: Link . The power supply turns on (the same symptom without these jumpers) and the green LED is blinking, but it does not give + 12V (with or without load). There are + 3.3V and + 5V voltages, but the most important one, i.e. + 12V, is missing. Is there anything else to connect, or is the power supply damaged?
    best regards
  • #2 13449284
    kacper_zet
    Rate: 25
    I have the same problem, when connected, the power supply starts the fans, gives a voltage of + 5V, but no + 12V.
    I tried to shorten pin 31 with 34 and 30 with + 12V as they advise in the topic with the same model of the power supply with the difference that the latter is a product of the company HP .
  • #3 16588867
    kacper_zet
    Rate: 25
    I managed to run the power supply, and we should shorten pins 31 from 34, and 26 to ground.
