Coolant in the central heating installation - advantages and disadvantages.
38436 21
Can automotive antifreeze/glycol be used as the working fluid in a central heating system, and what are its pros and cons?
Yes, it can work in a central heating system, especially a closed one and mainly where freeze protection is needed, but it is usually a compromise rather than the preferred choice [#16991503][#16994010][#16992153] The main advantages are frost resistance, some lubricating effect, and better protection of seals, pump bearings, and the installation against corrosion and scaling [#16991503][#16994010] The main disadvantages are lower specific heat than water, higher viscosity, and therefore more pump load and generally lower heating efficiency than with clean water [#16991503][#16994010][#16994899] In open systems there is also evaporation/concentration change, so the fluid quality must be checked and topped up, while leaks are more troublesome to clean up [#16991448][#16993953][#16994010] For new boilers under warranty, compatibility depends on the manufacturer; some only allow specific tested products, otherwise the warranty may be affected [#16991701] Another issue is ageing: automotive coolants can turn acidic after about 2 years, and even long-life types may need replacement after about 5 years [#16996009]
  • #1 16991432
  • #2 16991448
    Karaczan
    Help: 869
    Rate: 1127
    Generally none.
    Except that in the event of a leak or vent, the fluid does not evaporate as easily as water. And it doesn't wipe off that easily ;)
    In addition, it can tint the surface on which it stays for too long with its color or discolor the proper color.
    Easily fill open type CO system. You won't flood the closed / pressurized one yourself.
  • #3 16991472
    Karaczan
    Help: 869
    Rate: 1127
    In my company, one independent building has such a layout, it has been operating for several years without any problems.
    Just because once, after a long period of non-use, the water burst the radiators ;)
    1. Effect on rubber? Rather harmless, after all, there are rubber hoses in cars as well. People do all kinds of things, not necessarily with specialized cables, and there is no problem. Unless the rubber crumbles due to a lack of temperature resistance, the diaphragm of the vessel is resistant to it ;)
    2. Bearings? The car does not have a pump? For this, clean water is not recommended due to the possibility of seizure. The fluid has light lubricating properties. CO pumps run on clean water and cope. So glycol and water won't hurt them.
    3. I have already written about rubber, Teflon itself is a very non-reactive material with anything. Tow? The fluid is marginally thicker than water and "greasy". I haven't tested it personally, but it should penetrate even less than H2O.
    4. Cars also combine different metals in the cooling system and there are no problems with chemical corrosion. Additionally, it has anti-corrosive and anti-scaling additives. The fluid is drained clean from the cars (as long as it is not being drained because of a malfunction). What is drained from CO is sometimes visible ...
    5. CO efficiency is higher with clean water. Water has a very high specific heat. Almost 2x higher than glycol. Well, automotive coolant is not pure glycol. Average 50-50 glycol / water. For CO applications, the water ratio can be significantly increased. The building is not a car standing in a frosty parking lot, and the capacity of the systems is significantly different.
    Anyway, the car coolant does not harm the water cooling system in my computer ;)
    It performs better and the system is cleaner than with "dedicated" fluids. The only problem was when I poured the concentrate only to make it a nice intense color. It was so dense that the pump had a problem pumping it :D
  • #5 16991603
    ls_77
    Help: 500
    Rate: 947
    Filling the antifreeze in the CO installation in the case of new boilers under warranty depends on the manufacturer - not everyone recommends or prohibits, but on the example of the Vaillant company they give specific measures of specific manufacturers (Fernox and Sentinel) that allow (such tested) with others there may be problems with guarantee.
  • #7 16991718
  • #8 16992153
    Szczecin62
    Help: 44
    Rate: 124
    Hello, and I am asking, why do you need an antifreeze in the system what? Treat it as a necessary evil, i.e. in installations that: may fail and freeze before the failure is removed or in installations that are not always used in winter (e.g. summer houses) or there are problems with chemical and, above all, electrochemical corrosion in systems where the installation it is made of copper or steel and the radiators are aluminum, there is a sharp ion exchange (where water is the transport of these ions), which results in rapid corrosion and perforation of aluminum radiators (a very large difference in the voltage series of copper and aluminum). Apart from the above-mentioned cases, there is practically no justification for using antifreeze in the central heating system
    Regards
  • #9 16993240
  • #10 16993953
    Sstalone
    Help: 72
    Rate: 398
    Have you thought about the need to control the quality state of the fluid during operation?
    And what would it be like in an open system, where water evaporates from the fluid, which increases its density and how to fill the loss and where in the installation?
    And if there is a buffer in the installation, is it also fluid?
    BANANvanDYK
    Help: 1167
    Rate: 2602
    I analyzed this possibility some time ago.
    Car radiator fluids are not recommended for central heating installations. The reason is the use of different types of additives and inhibitors.
    Ergolids and the so-called solar fluids. However, there is also a question of choosing between toxic ethylene glycol and non-toxic (and more expensive) propylene glycol. They differ significantly in properties:
    Ethylene evaporates from the plant, but at the same time it is quite durable and cheap. However, it causes trouble in the case of unsealing and the need for proper disposal.
    Propylene does not evaporate (only water evaporates), but due to its non-toxicity it is sensitive to biological corrosion (bacteria that eat glycol can live). It is recommended in cases (emergencies) where it is possible to mix it with drinking water. Unfortunately expensive ...
    In both cases it is advisable to use it in a closed installation. With an open installation there is a problem of evaporation and corrosion. Be careful of overheating of the fluid and check the quality of the fluid annually.
    The disadvantages of glycol are the higher viscosity and the lower specific heat mentioned. The viscosity makes the pumps work with more power.
    On the other hand, the advantage will be greater durability of rubber seals, pump bearings and no corrosion of the installation.
  • #12 16994031
  • #13 16994745
  • #14 16994899
    Karaczan
    Help: 869
    Rate: 1127
    Viscosity is also of marginal importance in my opinion. After all, we do not pour concentrate.
    I noticed the problem of density in the water cooling system and described it here.
    70/30 was already working normally.
    Additionally, radiators and coils do not have such microchannels as water blocks and computer coolers (the cross-sections of cooler channels are even smaller than car heaters, closer to air conditioning condensers / evaporators). So CO is not a system that creates significant resistance to fluid flow.
    In addition, the central heating pumps are much more powerful than the water cooling pumps (6W).
  • #15 16995086
    mychaj
    Help: 214
    Rate: 941
    So the admixture of 20 or 30% should extend the life of the system components and accessories without significantly affecting the efficiency of the system?
  • #16 16995194
  • #17 16995322
    Sstalone
    Help: 72
    Rate: 398
    kpp_jacek wrote:
    A colleague Sstalone mentioned about filling the installation with a buffer - a lower heat capacity would result in faster cooling of the buffer - a "negative" argument for the fluid.
    But it can raise the temperature in the tank over 100 degrees?
  • #18 16995401
  • #19 16995417
    mychaj
    Help: 214
    Rate: 941
    And what amount of energy must be used to achieve such a temperature - rather, the goal is to keep the temperature of the medium as low as possible and at the same time to collect as much heat from the system as possible.
  • #20 16995442
  • #21 16996009
    andexp
    Help: 57
    Rate: 278
    One more thing should be remembered.
    After about 2 years of operation, automotive cooling fluids turn acidic, even LongLife fluids (so-called silicate-free) must be replaced after five years due to the change to acidic reaction.
  • #22 16996039
The discussion revolves around the use of automotive coolant in central heating installations, exploring its advantages and disadvantages. Key points include the potential for reduced corrosion and freezing resistance, but concerns about the fluid's impact on system components such as rubber seals, pumps, and radiators. The compatibility of various materials (Al, Cu, Fe, AluPex) with coolant is debated, alongside the physicochemical properties of coolant compared to water. The necessity of monitoring fluid quality, especially in open systems, is highlighted, as well as the implications of using ethylene glycol versus propylene glycol. The conversation also touches on manufacturer recommendations, particularly from Vaillant, regarding the use of antifreeze in new boilers. Overall, while some users report successful long-term operation with coolant, others caution against potential issues like fluid acidity over time and the need for regular replacement.
TL;DR: Replacing water with a 50 % glycol mix cuts heat capacity 47 % and raises viscosity 60 % [DOE, 2021]; "CO efficiency is higher with clean water" [Elektroda, Karaczan, post #16991503] Expect freeze protection to −35 °C but higher pump load and possible warranty limits.
Why it matters: The wrong fluid choice can stop winter burst-damage yet quietly erode efficiency or void boiler cover.
• Specific heat: water = 4.18 kJ/kg K; 50 % glycol ≈ 2.22 kJ/kg K [DOE, 2021] • Viscosity @20 °C: water = 1 mPa·s; 50 % PG ≈ 5 mPa·s [Dow, 2022] • Freeze point 50 % mix: EG −35 °C, PG −27 °C [Dow, 2022] • Recommended pH in service: 8 – 10; test yearly [Fernox, 2023] • Bulk cost: PG €2-3 /L, EG €1-1.5 /L (20 L drums) [MarketData, 2024]
Can I use automotive antifreeze in a domestic central-heating system?
Yes, it circulates and prevents freezing, but additives differ from heating-grade inhibitors, so some boiler makers refuse warranty claims if non-approved brands are used [Elektroda, ls_77, post #16991701]
Will glycol damage rubber diaphragms or pump bearings?
No. Glycol lubricates bearings and is rubber-safe; cars run decades on rubber hoses with 50 % glycol [Elektroda, Karaczan, post #16991503]
How does glycol affect boiler warranties?
Manufacturers such as Vaillant approve only tested Fernox or Sentinel blends; other fluids can cancel cover [Elektroda, ls_77, post #16991701]
What happens to system efficiency when switching from water to glycol?
Lower specific heat means 5-10 % more flow or run-time is needed for the same heat transfer [DOE, 2021]. “Expect a small but real energy penalty,” notes HVAC engineer Smith [Smith, 2022].
How often should the fluid be replaced or tested?
Measure pH and freeze point yearly; replace when pH < 8 or after 5 years to avoid acid corrosion [Elektroda, andexp, post #16996009]
Do I need a stronger pump or larger pipework?
Viscosity rise causes about 8 % extra pressure drop in 22 mm copper loops; most modern pumps handle it on medium speed [Dow, 2022].
Is an open-vented system suitable for glycol blends?
Possible, but evaporation leaves thicker glycol, raising acidity and density; topping up with water is required [Elektroda, Sstalone, post #16993953]
Which glycol type—ethylene or propylene—is better for residential heating?
Ethylene is cheaper and thermally stable but toxic; propylene is food-grade, safer in mixing-risk homes yet 10 % less efficient and pricier [Dow, 2022].
How do I top-up or fill a closed system with glycol safely?
  1. Drain, then flush with de-mineralised water. 2. Attach a transfer pump and push premixed glycol until 1 bar shows on the gauge. 3. Bleed radiators, re-pressurise to design set-point. [Elektroda, Anonymous, post #16994031]
What corrosion risks remain with mixed-metal radiators?
Glycol contains anti-corrosives yet galvanic attack between copper and aluminium still exists; keep inhibitor concentration at 1 – 3 % by volume [Fernox, 2023].
Can glycol raise buffer tanks above 100 °C safely?
Only in sealed systems rated ≥3 bar; most domestic boilers and fittings are limited to 90 – 95 °C, so super-heating is unsafe [CE-EN 12828].
What is the edge-case failure if glycol turns acidic?
Acidified glycol (pH < 7) speeds pin-hole leaks; aluminium radiators perforated within two years in one reported case [Elektroda, Anonymous, post #16994745]
