Mercedes W211 Ignition Issues - Key Switch, Fish Key, Bolt, Central Remote, Emulator & No Errors
ptr92 17403 2
  • #1 16991619
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    standard case, in Mercedes W211 no reaction to insert the key in the ignition, the central one from the remote control works.
    But the non-standard stuff is that everything works 100/100 on the table.
    In addition, the car will accept the key and release the bolt, as you press any button on the remote control inside the ignition.
    The supplies are fine.
    On the emulator, the bolt is the same. In SD the key insertion is recognized. And of course, no errors.
    Anyone had a similar topic?
  • #2 16991734
    adamski123
    Help: 46
    Rate: 250
    Hello, I used to have this case, the bolt released everything ok, it turned out that the starter fell
  • #3 16992250
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    But the bolt doesn't let go. After pressing the switch on the remote control, the bolt unlocks, the ignition is released and the car starts.
    In the morning the head is fresher, so the topic is overwhelmed. On the table, if I give power below 12.5V, it doesn't work either. Ignition switch damaged.
    I'm closing the topic
