Sony Xperia XA Not Powering Up, Vibrates and Displays Empty Battery Icon
tuszyn1233 3267 5
  • #1 16992286
    tuszyn1233
    Rate: 12
    Hello, I have a problem with Soniacz, the phone stopped turning on after discharging, after connecting the charger I react with vibration and the empty battery icon is lit (as if the battery was not detected), I disconnected the battery and the reaction is the same.
    Where to start?
    Maybe a fuse has blown out?
  • #2 16992326
    sylweksylwina
    Help: 1881
    Rate: 2348
    And the battery voltage?
  • #3 16992359
    tuszyn1233
    Rate: 12
    I replaced the second battery and nothing has changed
  • #4 16992517
    sylweksylwina
    Help: 1881
    Rate: 2348
    Well, it's probably a damaged charging system, or some protection for the USB port.
  • #5 16992730
    tuszyn1233
    Rate: 12
    It was checked on a charged battery in another phone and no reaction after pressing the Power button, so I exclude damage to the USB connector.
  • #6 16992845
    sylweksylwina
    Help: 1881
    Rate: 2348
    I have not written that the USB connector is damaged.
