Sony Xperia Xa: LCD Screen Unresponsive After Water Exposure - Solutions & Repair Options
PatrykSr1 2487 3
  • Water-damaged Xperia has backlight but no LCD image
    #1 16348490
    PatrykSr1
    Unfortunately, my Xperia recently landed in the water, it was there for a very short time, but it was enough for her .. All the functions in it work, it starts, etc. but nothing can be seen on the LCD, i.e. as if it is gently illuminated but there is no image, the touch works because when you turn on the phone you can hear the touch sound .. Will someone give you an idea? Today I cleaned the plate with a stick and isopropanol and gently heated it with a heat gun, unfortunately it did not help.
  • #2 16348524
    KamGr
    Help: 77
    Rate: 203
    In this case, you are left with bathing the plate in an ultrasonic bath. Alternatively, try to clean the iso contact from the display, if nothing will help, you will probably have to replace the LCD.
  • #3 16349172
    PatrykSr1
    Unfortunately, after cleaning the connector, it did not help ... Gentlemen, maybe someone else has an idea? Everything works, touch, you can hear us going through the menu only no picture ..
  • #4 16349310
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Broken LCD and no ideas will help here.
