Sony Xperia Z1 C6903 Battery Draining Rapidly - Sudden Shutdown at 44% to 1%, Charging Issues
TheRechot 3429 9
Why does my Sony Xperia Z1 suddenly shut down from around 44% battery to 1%, and what should I check first?
The sudden drop from about 44% to 1% is most likely a failing battery, and the first recommended fix is to replace the battery [#16534634][#16536306][#16537967] Similar cases were reported where the phone turned off suddenly at about 40–43% and the battery was the cause [#16536090][#16537967] One reply notes that with normal use batteries usually do not fail this way, but you may have gotten a bad one [#16534635] If you want to look beyond the battery, the thread says finding a short circuit would require a schematic, a multimeter, and disassembling the phone [#16536306]
  • #1 16534622
    TheRechot
    Hello. Recently, I have been struggling with a quite annoying problem related to the battery in my Sony Xperia Z1 C6903 smartphone. Well, I've never had a problem with the battery. Fully charges up, everything works. Recently, however, during normal use with a charge of 44%, my phone suddenly turned off. Just. After restarting, its status was 1%. As if it discharged in a second. I thought it was a one-time "prank", but yesterday I had exactly the same situation. The phone is not somehow tortured with some applications of unknown origin, it is normally used, not broken, without any so-called "spider veins". The fact is that it is already old, because I have it for 2.5 years and it is long after the warranty, but such behavior is unacceptable. I would like to add that I charge it with the original charger and changing the battery on my own is unlikely to be an option due to its water resistance. If someone encountered a similar situation, I would ask for help. Thanks in advance.
  • #2 16534634
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    At the beginning, replacing the battery, you can think of nothing else.
  • #3 16534635
    krzysiek12sos
    Help: 51
    Rate: 85
    The batteries don't sit down that often with normal use, but you may have come across an unlucky one. This is what it looks like.
  • #4 16534647
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    krzysiek12sos wrote:
    Batteries don't sit down as often with normal use
    Can you develop it?
    Yesterday I changed the battery in A5 2016 that had been used for 9 months, it swelled and the flap has become cough.
  • #5 16534687
    krzysiek12sos
    Help: 51
    Rate: 85
    As you can see, because you are probably working at it, the newer batteries are of lower quality. Not so long ago, I took the Sony K805 out of the closet and after many years of work and then aging, I kept the battery for 7 days with little use. It's just a myth now :)
  • #6 16534706
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Well, I've been working on it for over a dozen years and that's why I wrote that you need to replace the battery and you write completely pointless in one post differently and in the other differently.
  • #7 16534721
    krzysiek12sos
    Help: 51
    Rate: 85
    I will say this: you can not say that new batteries do not last, because I have a Sony M2 and after 4 years the battery is nice, but what matters is the way of using, discharging, the charger used and the application that finish the batteries. So it can be different.
  • #8 16536090
    TheRechot
    So only battery replacement is an option? Because today I had the same thing and I noticed that it is done exactly at 43%. Does it matter? Maybe there is a short circuit at this level?
  • #9 16536306
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Finding faults begins with the simplest things, and this is battery replacement.
    You want to look for a short circuit, then look for a diagram in a paw, a table meter, a telephone disassemble and go to work.
  • #10 16537967
    Radow
    Help: 5
    Rate: 35
    In z1 I had a similar problem. Bareria to be replaced in my case.
    For example, 40% and discharged in a moment. As soon as he fell in this area, it turned off.
The discussion revolves around a battery issue with the Sony Xperia Z1 C6903, where the user experiences sudden shutdowns at around 44% battery life, dropping to 1% upon restart. Responses suggest that battery replacement is likely necessary, as the device is over two years old and may have developed faults. Some users share similar experiences, indicating that batteries can fail unexpectedly, particularly as they age. There are mentions of the quality of newer batteries and the importance of proper usage and charging practices. A few responses also hint at the possibility of a short circuit affecting battery performance, but the consensus leans towards battery replacement as the primary solution.
