Splitting Knotty Wood Blocks & Roots: Hydraulic Splitter vs. Chainsaw vs. Drill Splitter & More
pawellukaszelektroda 10722 16
How can I split very knotty wood blocks and roots when a wedge and hammer are not an option?
For very knotty blocks and roots, a hydraulic splitter is the most practical solution, but a 10-ton machine is usually only enough for normal wood; badly twisted roots or stump-like pieces may need 20–30 tons or even more [#16992821][#17009042] A conical auger/drill splitter can work best on rooty, knotty wood if it is driven by a strong motor/PTO and mounted very solidly, but it can jam hard, especially in dry beech or tightly twisted wood [#16992821][#16993052][#16993135] A chainsaw is possible, but it becomes blunt very quickly in hard, knotty wood and is hard on both the machine and the operator; if you use one, cut the piece into slices and finish with an axe [#16992821] Several replies say the only reliable tools for the worst pieces are wedges and brute force, or a wide wedge on an actuator, but even then the material can be so tough that it stalls drilling/splitting attempts [#16992821][#16993052] If you only have a few such pieces, it may be more economical to burn them as-is rather than invest time and equipment [#17007251]
  • #1 16992756
    Pupil
    Rate: 111
    I analyze various methods of splitting / chopping wood, especially blocks and roots.
    I would like to point out that splitting with a wedge and a hammer is not an option.
    From what I can see it comes into play:
    - hydraulic splitter,
    - chainsaw - preferably stationary (table),
    - drill splitter - checked ... for knotty blocks or roots ... poorly ...
    An interesting solution for a mechanical machine based on a cut rim, but not too much to the roots, but to thicker branches:
    https://www.youtube.com/watch?v=f5zURm2iXCo
    For branches (even 10 cm), I can see that a roller chipper (called as a roll, link below) is great:
    https://www.youtube.com/watch?v=EYtFzQvGNc4
    I have reviewed the hydraulic log splitters on the river ... but there are opinions that even an over 10 ton cylinder may not be able to cope ...
    What are your ideas?
  • #2 16992821
    Lisek64
    Help: 218
    Rate: 596
    Only a wedge and brute force or drilling, i.e. a conical auger with a suitably strong motor, a hardened auger and a solid block mounting, can do the best with sękaczami and roots. The uniform pressure of a 10 ton hydraulic press is suitable for "normal" pads. To the broken buttocks, probably 10x bigger. Chainsaw? Some solution as long as you have lots of replacement chains. With such hard wood it becomes blunt as on concrete and the longitudinal cut is a torment for the machine and the operator. Unless you cut into "slices" and finish the job with an ax :-)
  • #3 16992862
    Pupil
    Rate: 111
    Well, the auger would be driven from the PTO. The biggest one I found now is 107mm in diameter.
    But there is a case that sometimes it will go to the end and the wood will squeeze very hard
    cone ... and you also have to combine.
    Below is a hydraulic splitter in action with knots:
    https://www.youtube.com/watch?v=w_-4Pk61Ha0
  • #4 16992880
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Use a geared motor. 15 rpm and 1kNm.
  • #5 16992912
    Pupil
    Rate: 111
    Okay, but it's not a lack of power but the drill bit.
    I think you need to reverse the rotation with an additional gear, because the PTO does not work "backwards".
    Drills can do:
    https://www.youtube.com/watch?v=lEgjbkW2J6M
    But I have not found this shape in Pl .. yet.
  • #6 16992920
    Lisek64
    Help: 218
    Rate: 596
    So 17 tons can handle knots, but what if it was hard wood like beech? I don't know if she could do it. There is probably no golden mean. although the stump grinder ultimately remains ;-)
    https://www.youtube.com/watch?v=j9KalDL8LZY
  • #7 16993052
    mychaj
    Help: 214
    Rate: 941
    I once brought beech pieces of such "buttocks" from a forester, almost 2m / six, I did, as I remember well, 6 or 8 chains, and I chopped it with wedges and a hammer 15 kg,
    When it is tightly "twisted" at the root, it is only a wide wedge on the actuator, but the power must be specific, the auger dies, goes in and gets stuck.
    Er ... these movies are a shade not a tree - a decent beech stump would extinguish them like a beer can.
  • #8 16993093
    Pupil
    Rate: 111
    Well ok, and the auger on the WOM and a few dozen KM will not handle it?
  • #9 16993135
    mychaj
    Help: 214
    Rate: 941
    It depends on the log you fasten :-) I had such that and 4 wedges barely made it ... :-)
    I will add: if fresh beech is going somehow, but if the hell is dry ...
  • #10 17007251
    wnoto
    Help: 58
    Rate: 744
    It all depends on how much you do (roots and really gnarled blocks).
    How little would I leave for the fire (that's what I do) and I don't get tired - it's a waste of time and equipment for such fun.
    The wedges I bought back then were worth more than the wood I split them.
    What I do not like fiscars (and I have some steam in my hands) goes to the fire (I always miss such wood)
  • #12 17008973
    mychaj
    Help: 214
    Rate: 941
    There is no more than 3kW of this engine, see what this guy has wood - dry, no overgrowth, soft, with a small hatchet I could cut it in a few minutes.
    When I have such a beech without knots, chopping is pure pleasure, the machine is unnecessary because it falls apart by itself.
    But all you need is a few knots or twisted at the root and it gets tough, the wedges and the hammer are in motion.
  • #13 17009042
    kortyleski
    Help: 957
    Rate: 3860
    A hydraulic splitter is the only solution. Just the actuator issue. Achieving a pressure of 20-30 tons is not a problem. And with such force, he will squeeze the water out of dry wood.
  • #15 17010177
    mychaj
    Help: 214
    Rate: 941
    LOOK ... it has power - from my backyard: to overturn the brewing kettle of 750L (its weight was about 900 kg) on the eccentricity the pump had 3kW and gave a pressure of 80bar for two actuators with a diameter of about 80mm and a stroke of 750mm.
  • #16 17011485
    wnoto
    Help: 58
    Rate: 744
    pawellukaszelektroda wrote:
    They will certainly burn longer, which is worth using.
    You mean you'll get more energy?
    Where does this knowledge come from? And why are they burning longer?
  • #17 17011683
    Pupil
    Rate: 111
    The roots are harder, denser, denser ... more mass in the same
    volume. They "keep" heat longer - that's what I meant.
    Well, maybe it's a generalization.
The discussion revolves around various methods for splitting knotty wood blocks and roots, focusing on hydraulic splitters, chainsaws, and drill splitters. Users express skepticism about the effectiveness of hydraulic splitters, even those with over 10 tons of force, particularly on hard woods like beech. The challenges of using chainsaws on tough wood are highlighted, as they tend to dull quickly. Alternatives such as conical augers and geared motors are suggested, with emphasis on the need for sufficient power and the right equipment to handle gnarled roots. The conversation also touches on the efficiency of roller chippers for smaller branches and the importance of using the right tools for specific wood types. Videos demonstrating various machines and techniques are shared to illustrate points made in the discussion.
TL;DR: For knotty hardwood and roots, plan on 20–30 tons; "A hydraulic splitter is the only solution." This FAQ compares hydraulic, chainsaw, and cone (drill) splitters, with PTO tips and safety. For DIY firewood cutters deciding how to split gnarly blocks and roots. [Elektroda, kortyleski, post #17009042]
Why it matters: Choosing the right method saves chains, prevents stuck augers, and avoids wasting time or breaking gear.
What tonnage hydraulic splitter should I choose for knotty blocks and roots?
Target 20–30 tons. Users report lower-force units stall on twisted grain and root flare. A wider, tough wedge helps start the split. Keep the beam short and rigid to avoid flex. If you often tackle large root butts, choose the higher end of that range. [Elektroda, kortyleski, post #17009042]
Is a cone (drill) splitter good for roots or sękacze?
Use caution. In twisted root wood, a cone often bores in and seizes. As one expert put it, “the auger dies, goes in and gets stuck.” You need strong reverse drive and a rigid mount. Even then, expect stalls in dense, cross‑grained beech. [Elektroda, mychaj, post #16993052]
Can a chainsaw replace a splitter for gnarly logs?
Not well. Knots blunt chains like concrete. Ripping with the grain overheats the saw and drains bars and chains quickly. If you must, cookie the log into discs, then finish with wedges or a splitter. Keep spare chains on hand. [Elektroda, Lisek64, post #16992821]
Will a PTO-driven cone handle big roots if I add reverse?
Reverse helps free a stuck cone because most PTOs lack backward rotation. Add a reversing gear or hydraulic motor with bidirectional control. Use a hardened cone and very secure log clamping. Even then, expect stalls in tight grain. [Elektroda, pawellukaszelektroda, post #16992912]
Is it worth processing gnarly roots, or should I burn them as-is?
If you only have a few, many users burn them whole rather than stress tools. Time, chains, and wedges can cost more than the wood’s value. Save effort for clean, straight-grained logs that split quickly and season predictably. [Elektroda, wnoto, post #17007251]
Do roots really burn longer or give more heat?
One user argues roots are denser and hold heat longer. The thread offers no data, only that impression. Treat it as anecdotal and test on your stove. Split to size that fits, and season thoroughly for safe combustion. [Elektroda, pawellukaszelektroda, post #17011683]
Why do some videos show tiny motors splitting logs effortlessly?
Context. A 3 kW setup can split soft, dry, knot‑free wood on camera. Swap in dry beech with knots and it stalls. Don’t size your machine by viral clips. Match tonnage and wedge to the worst wood you plan to process. [Elektroda, mychaj, post #17008973]
How much hydraulic power do I really need? Any real numbers?
Example from the thread: a 3 kW pump at about 80 bar powered two 80 mm cylinders with 750 mm stroke to move ~900 kg. That shows how pressure, bore, and stroke translate to force. Scale up tonnage for splitting duty. [Elektroda, mychaj, post #17010177]
What’s the safest way to run a cone splitter? (3-step How‑To)
  1. Use a geared motor around 15 rpm with roughly 1 kNm torque.
  2. Rigidly mount the cone; clamp logs securely at working height.
  3. Feed slowly; keep a clear reverse to back out immediately on bind. [Elektroda, Strumien swiadomosci swia, post #16992880]
How does moisture and species change difficulty?
Fresh beech splits acceptably. Dry beech can resist multiple wedges and heavy blows. Knots and twisted grain raise the force needed dramatically. Size your splitter for dry, knotty hardwood, not for soft, straight stock. [Elektroda, mychaj, post #16993135]
Could a 17‑ton splitter be enough on knots and hard species?
It may handle some knots, but hard species like beech can still stop it. Expect to step up tonnage or pre‑segment the log. Consider higher force plus a robust wedge to initiate and propagate the split. [Elektroda, Lisek64, post #16992920]
What about using a stump grinder instead of splitting?
A stump grinder removes the mass instead of splitting it. It’s a disposal option for root butts that defy saws and splitters. Choose it when the goal is removal, not firewood recovery. [Elektroda, Lisek64, post #16992920]
Why do some hydraulic splitters “feel” weak on tough logs?
Uniform pressure helps on straight grain, but twisted roots need much higher peak force. Under‑sized cylinders or flexing frames waste energy. Boost tonnage and stiffen the structure to drive the wedge without deflection. [Elektroda, kortyleski, post #17009042]
