[Solved] Husqvarna Saws Chain & Guide Dilemma: Oregon vs. Mastiff & Strong (38cm, .325, 64 Links)
jarekstryszawa 31611 9
Czy warto kupować tańsze zamienniki prowadnicy i łańcucha .325 64 ogniwa do pilarki Husqvarna 38 cm zamiast Oregon?
Nie ma większego sensu brać tanich zamienników prowadnicy i łańcucha; do takich zastosowań lepiej zostać przy Oregonie albo oryginale [#16829920] Tańsze zamienniki były opisywane jako szybciej się zużywające, robiące „drut” na prowadnicy i czasem z niepasującymi otworami smarowania [#16829920] Do cięcia w brudnym drewnie lepiej pasuje łańcuch półdłuto niż pełne dłuto, a na piasek są specjalne modele typu multicut [#16834980][#16845004] Padła też rada, by kupować łańcuchy na oryginalnych ogniwach Oregon i polować na okazje, zamiast testować niepewne produkty [#16847788][#17598346]
  • #1 16794216
    jarekstryszawa
    Help: 49
    Rate: 482
    A question for the pilots.
    For grubbing stumps in the fields (before cutting - I'm cutting down with the ground) I use Husqvarna saws with 38 cm guide. Until now, I used only guides and Oregon chains with a hole for additional bearing lubrication. They do not have light because it is undercutting with sand, soil, etc. so I use a few such sets for the season ...
    Now such a set of Oregon costs about PLN 160 (length 38 cm, chain pitch .325 ", 64 links)
    However, I have a dilemma because searching for Oregon I noticed the alternatives (also the guide plus 2 chains):
    - MASTIFF for PLN 40
    - STRONG for PLN 49
    I have not dealt with such inventions so far - is there any sense to bother with that?
  • Faster wear and oil-hole misalignment with replacements
    #2 16829920
    Cinek_Barczewo
    Rate: 26
    Hello, I would let it go ... The price had to have its basics. I used several times replacements and unfortunately I have to say faster wear, the formation of a "wire" on the guide at a rapid pace, it also happened that the holes from the lubricator did not coincide with the channel in the saw (the guide was matched to the saw) I also own several Husqvarna saws and everywhere is Oregon, or the original, although more expensive solutions, you also pay for the mark, unfortunately ....
  • #3 16834727
    jarekstryszawa
    Help: 49
    Rate: 482
    OK thanks for the information.
  • #4 16834980
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    I do not know what type of chains you use, but a half-chisel type chain would be more suitable for such a cut (of course a good brand, eg. Oregon).
    Half-chisel, i.e. with such a profile:
    The full chisel has such a profile and becomes more dull in "dirty" wood.
  • #5 16845004
    wnoto
    Help: 58
    Rate: 744
    for sand are special models probably called multicut
  • #6 16845272
    jarekstryszawa
    Help: 49
    Rate: 482
    Yes, they only require special grinding discs.
  • #7 16845485
    wnoto
    Help: 58
    Rate: 744
    I sharpen with a file. The discs wear the chain much harder. I think that at least 2x faster.
    But the fact I do not know what to sharpen such a chain. I did not work on the subject
  • #8 16845955
    jarekstryszawa
    Help: 49
    Rate: 482
    Surely they consume faster (the pressure is the tendency to overheat the blade, moreover, it collects more), but for me the sharpener wins in the category of speed and convenience ;-)
    When I take a few days leave, when I come back in the afternoon with a few blunted chains and I still have to grasp the dirty saws for the next morning is the only alternative ...
  • #9 16847788
    E8600
    Help: 529
    Rate: 2520
    I recommend chains on the original Oregon links. Such an example is the "flora best" brand of the Lidl brand. I managed to hit the opportunity on the allegro for 2 such chains with shipping, I paid PLN 40 for the 3/8 half-chisel scale (40 cm guide). Chains, in my opinion, very good sharp and like with any chain like new it goes like in butter. Until we overheat or jam the guide, it stretches normally.
    With chainsaws it's a good part of it, it has original guides and chains, which is why some buy them on promotions leave a chain and guide and the rest gets a slightly cheaper allegro and in this way they have a good cutting set at a cheap price.
    As for sharpening, of course, the file will extend the life of the chain especially when we cut the material with surprises in the form of nails and sharpen the chain with a nail file after 10-15 minutes and do not need to be dismantled from the saw.
    To buy cheaply on allegro, you have to add a bookmark and sometimes there is a look at how something cool is cheap, we buy it for stock. You should look even if you do not need how many things I bought in this way for half the price. :) The day before yesterday I bought a clutch basket for my saw using the free shipping - Allegro parcel machine.
  • #10 17598346
    jarekstryszawa
    Help: 49
    Rate: 482
    However, I bought verified Oregon sets, I did not want to test uncertain products on myself ...
The discussion revolves around the choice of chains and guides for Husqvarna saws, specifically for grubbing stumps in challenging conditions involving sand and soil. The user has been using Oregon chains and guides but is considering cheaper alternatives from brands Mastiff and Strong. Responses indicate that while cheaper options exist, they may lead to faster wear and compatibility issues. Users recommend sticking with reputable brands like Oregon for better durability and performance, especially when dealing with dirty wood. Additionally, the discussion touches on chain types, with half-chisel chains being suggested for such applications, and mentions the importance of proper sharpening techniques to extend chain life.
