Reviews of Bose Acoustimass-10 Series V Speakers: Amplifier Pairing for 28m2 Living Room
6999 14
Can Bose Acoustimass-10 Series V speakers be paired with a good amplifier for a 28 m² living room, and what setup would work better?
For a 28 m² living room, this Bose home-theater set is too small; floorstanding front speakers are recommended instead, and even a Tonsil Siesta 5.1 set was suggested as a better fit for that room size [#17009391][#17010401] If you want mostly music, the advice was to choose stereo floorstanders rather than a home-theater package [#17010401] If you want both cinema and music, the best solution suggested was an AV receiver with pre-outs, so you can drive the front speakers through a separate amplifier and connect the other channels directly to the receiver [#17011139] Onkyo or Marantz were mentioned as reasonable receiver brands for this kind of setup [#17016275] It was also stressed that sound preference matters a lot, so it is best to listen to several models before buying [#17016275]
    indianin11
    Help: 49
    Rate: 26
    For such a surface, you need floor columns for the fronts, these children from the auction will die in such a room. For PLN 200 more you have a Siesta 5.1 set and it will play in 28 m2.
  • #3 17009529
  • #4 17010097
    indianin11
    Help: 49
    Rate: 26
    Are we talking about home cinema all the time? If I am wrong, correct me.
  • #5 17010186
    Pablo1964
    Moderator
    Help: 507
    Rate: 642
    What are you going to use the equipment for?
  • #6 17010352
  • #7 17010401
    indianin11
    Help: 49
    Rate: 26
    In the link from the first post you posted a set of home theater speakers.
    As only for stereo music, there are two floorstanders. For my part, I can recommend Tonsil Siesta, but only if you don't listen to metal because they are average for this genre.
  • #8 17010532
    indianin11
    Help: 49
    Rate: 26
    Home theater receivers play stereo music "incidentally" and we can only talk about quality with the highest models. The solution may be to buy a KD receiver with pre out. In this case you connect the amplifier with front speakers to the amp, and the rest of the speakers to the receiver. You have a cinema and stereo in good quality.
  • #10 17011159
    indianin11
    Help: 49
    Rate: 26
    How much money do you have?
  • #12 17012679
  • #13 17016173
  • #14 17016275
    indianin11
    Help: 49
    Rate: 26
    Buy ampli with pre out 5.1. Here I suggest Onkyo or Marantz. Plus an amplifier and a set of speakers. It's best if you listen to a few models and choose what's best for you. It's hard to advise anything specifically, because everyone has different sound preferences, e.g. klipsch are great in the cinema, but in music they will not suit everyone and will not sound well with every amplifier.
  • #15 17016519
The discussion revolves around the suitability of the Bose Acoustimass-10 Series V speakers for a 28m2 living room when paired with an appropriate amplifier. Users suggest that for optimal performance, especially for music listening, floor-standing speakers may be more effective than the Acoustimass set. Recommendations include considering a 5.1 set like the Tonsil Siesta, particularly for those who do not listen to metal music. The conversation also highlights the importance of using a home theater receiver with pre-outs to connect an amplifier for better sound quality in both cinema and music applications. Brands like Onkyo and Marantz are mentioned as potential choices for receivers. The user expresses a budget of PLN 7,000 to PLN 8,000 for the setup.
TL;DR: For mixed music/cinema in a living room, use a 5.1 receiver with pre‑out feeding a stereo amp; “Home theater receivers play stereo music ‘incidentally’.” This hybrid preserves music quality and surround convenience. [Elektroda, indianin11, post #17011139]
Why it matters: It helps buyers who want strong stereo music and home theater from one system without wasting budget.
Is the Bose Acoustimass 10 Series V a good match for a 28 m² living room?
Not ideal. For this room size, use floorstanding fronts. Small cube satellites struggle to fill 28 m² with balanced sound and dynamics. This advice came from an experienced forum member assessing that “these children… will die in such a room,” pointing to larger fronts as a better fit. [Elektroda, indianin11, post #17009391]
I care more about music than movies—what should I buy first?
Start with a solid stereo: two quality floorstanding speakers and an amp. That yields better musicality than a compact 5.1 cube set. You can add theater pieces later. As one helper put it, for stereo music, go with two floorstanders and pick models that suit your genres. [Elektroda, indianin11, post #17010401]
How do I get both good stereo and home theater in one setup?
Use an AVR that has 5.1 pre‑outs and feed those front pre‑outs into a dedicated stereo amplifier. Drive the front speakers with the stereo amp; let the AVR handle center, surrounds, and processing. This hybrid preserves stereo quality while enabling surround. [Elektroda, indianin11, post #17011139]
What does “pre‑out 5.1” actually mean?
Pre‑outs are line‑level outputs from an AVR’s decoder section. A “5.1 pre‑out” allows you to route channels, especially the front left/right, into an external stereo amp. That way, movies use all speakers, but music benefits from the better stereo amplifier. [Elektroda, indianin11, post #17011139]
Which AVR brands were suggested for this approach?
Onkyo or Marantz AVRs with pre‑out were recommended. The guidance also stressed listening before buying, since voicing differs. It added that certain speaker brands excel in cinema but may divide opinion in music, underscoring the need to audition. [Elektroda, indianin11, post #17016275]
Are Klipsch speakers a safe bet for music?
They can be thrilling in home theater, but may not suit all music tastes or amps. The advice warned they won’t sound good with every amplifier. Treat them as a demo priority, not an automatic choice. That’s an important edge case to consider. [Elektroda, indianin11, post #17016275]
What budget should I plan for speakers and amplification?
The thread settled around 7,000–8,000 PLN. That range can cover an AVR with pre‑out, a stereo amp for the fronts, and capable speakers if you shop carefully and audition. Set aside funds for cabling and stands if needed. [Elektroda, Anonymous, post #17012679]
Is there a value alternative to the Bose set mentioned?
Yes. One reply noted a Siesta 5.1 set available for about 200 PLN more than the linked auction’s price. That highlights how conventional speakers can offer better room coverage and value at similar cost. Always compare with a demo. [Elektroda, indianin11, post #17009391]
Will an AVR alone satisfy me for stereo music?
Only at the very top tiers. “Home theater receivers play stereo music ‘incidentally’,” so quality improves meaningfully when you add a dedicated stereo amp for the fronts via pre‑out. This preserves musical nuance and dynamics. [Elektroda, indianin11, post #17011139]
What speaker size works best in a 28 m² room?
Use floorstanding fronts for proper scale and headroom. Small satellites risk thin mids and limited dynamics in larger rooms. For immersive music and cinema, larger mains create a stable soundstage and better bass integration. [Elektroda, indianin11, post #17009391]
How should I connect an AVR with a stereo amplifier? (3‑step)
  1. From the AVR’s Front L/R pre‑outs, run RCA cables to the stereo amp’s inputs.
  2. Connect your front speakers to the stereo amp; center and surrounds to the AVR.
  3. Run AVR calibration, setting front speakers as “Large/External Amp” as available. [Elektroda, indianin11, post #17011139]
I’m new and feel lost—what’s the simplest next step?
Define your split between music and movies, then audition a few speaker pairs. Bring familiar tracks. Follow with an AVR that has pre‑outs and add a stereo amp later if needed. Personal preference should drive the final choice. [Elektroda, indianin11, post #17016275]
