Audi A4 B5 1.6 Engine Wiring Diagram for Candles - Seeking Photo & Guidance
pawel16150 27072 6
  • #1 17011229
    pawel16150
    Level 30  
    Help: 204
    Rate: 640
    Does anyone have a wiring diagram for candles? engine 1.6
    I am asking for a photo
    Added after 15 [minutes]:
    Anybody?
  • #2 17012105
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. The dome should be cylinder numbers from 1 to 4 at the exits for individual cylinders.
    Connect cables from the dome with the corresponding cylinders (candles). The first cylinder from the timing, 4th from the chest. The order of wires 1342 going to the left. 1 is marked with a notch visible after removing the dome on the camera body. Looking at the engine like this:
    2 .... 1
    4 .... 3
    You will do some research and find a job.
  • #3 17013916
    pawel16150
    Level 30  
    Help: 204
    Rate: 640
    Zero characters on the kopeck has anyone can picture?
  • #4 17013927
    Pedros050
    Help: 2471
    Rate: 3927
    And what I wrote above you have to take the dome off. Read with understanding.
  • #5 17013928
    andrzej20001
    Help: 1578
    Rate: 6669
    if you did not move the camera ... I found it ... and it's best to check when you have compression and your finger shows which cylinder it is. In an era of ubiquitous cells with the camera, it's a pity not to use it :)
  • #6 17013941
    pawel16150
    Level 30  
    Help: 204
    Rate: 640
    not just the wires I took off to replace the dome, and simply access is dim
  • #7 17013953
    andrzej20001
    Help: 1578
    Rate: 6669
    Photo, pen and dots ... a bit of invention. Ignition order is 1-3-4-2 according to camera rotation. Look for 1 cyl. when you have a compression ignition then it points the finger of the manifold (closing the hole with a finger). A helper needed to start the starter. https://www.elektroda.pl/rtvforum/topic959000.html
The discussion revolves around obtaining a wiring diagram for the ignition system (candles) of the Audi A4 B5 with a 1.6 engine. Users provide guidance on the cylinder numbering and wiring order, indicating that the ignition order is 1-3-4-2. A photo link is shared to assist with visual reference, and suggestions are made to check cylinder compression for proper identification. The need for a clear photo of the wiring setup is emphasized, as the original poster has difficulty accessing the wires after removing the dome.
