Audi A4 B5 (1996) - Dipped Beam Issue: Position & Long Lights Working, No Voltage on Fuses
tomasz.golebiewski 15786 3
  • #1 16956880
    tomasz.golebiewski
    Hello all,
    I was looking for a similar topic on the forum, I could not find anything.
    The problem is unusual. The position lights work, the long lights also work, but the passing lights dies. Light bulbs are good, fuses not burned. I will give a hint that there is no voltage on the dipped beam fuses. First, my right light died, and after a while it was only left and I do not have any right now. Do you know what it can be? Where to look for a problem?
    I will be grateful,
  • #2 16957068
    pawel16150
    Level 30  
    Help: 204
    Rate: 640
    The so-called spider switch fault
  • #3 16957473
    Ireneo
    Help: 747
    Rate: 2470
    A typical problem, you did not look well and even did not deign to take control and check yourself.
  • #4 16958670
    grzegorzbuczylo
    Help: 37
    Rate: 296
    Concluding from what you write, the switch fell but before that the bulb was burned.
    The switch under the steering wheel can be repaired.
