Volkswagen Fox 1.2 petrol weseck engine and ESP turns on while driving
artur17lok 8382 7
  • #1 17013414
    artur17lok
    Hello, I am the owner of Volkswagen Fox 1.2 petrol 2006. When the frost is greater and I just leave the block, the esp indicator and check engine light up. The engine starts jerking, it won't be possible to keep going and I have to turn the car off and start again. Then everything is ok. I replaced the candles with new ones. The computer does not show any errors. I checked the pressure on the pistons, 9.5 on all three. What could be the reason? Thanks for the help.
  • #2 17013662
    migmig85
    Help: 85
    Rate: 337
    What, buddy, did you do diagnostics?
    And ESP turns off, not on.
  • #3 17014043
    andrzej20001
    Help: 1578
    Rate: 6675
    there is no such option if the engine light is on. Misfire, if the spark plugs are new there may be a coil.
  • #4 17015100
    migmig85
    Help: 85
    Rate: 337
    We will find out, buddy, what did you do computer diagnostics ??
  • #5 17015326
    kacper082
    Help: 21
    Rate: 143
    Check the accelerator pedal sensor. He is guilty of the check engine and epc. I understand that when these controls appear, there is no power. Everything returns to normal when the engine is turned off.
    Moderated By T5:
    3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
    Warning.
  • #6 17015863
    andrzej20001
    Help: 1578
    Rate: 6675
    Sure. The soothsayer Maciej was found
    Moderated By CameR:
    Reg. 3.1.11. Don't post messages that add nothing to the discussion.
  • #7 17030669
    artur17lok
    I did a computer diagnostics at the mechanic's (I don't know the computer) again and it showed that the ignition falls out on the first cylinder.
    I bought one new coil and replaced it on each cylinder, but the problem keeps arising.
  • #8 17030740
    sanfran
    Help: 966
    Rate: 3007
    You need to change the mechanic to one who has a diagnostic device for VW cars. Most likely, he connected a universal scanner that cannot read codes from other modules. And here it may be important what other modules signal, because they can force the engine power reduction
The discussion revolves around a 2006 Volkswagen Fox 1.2 petrol experiencing issues with the ESP indicator and check engine light activating during cold weather, leading to engine jerking and power loss. The owner has replaced spark plugs and checked piston pressure, but the problem persists. Responses suggest potential causes including a faulty accelerator pedal sensor, ignition coil issues, and the need for proper diagnostics with a VW-specific scanner to identify underlying module signals affecting engine performance.
