Calculating Wrench Rotation Angle for Specific Bolt Tightening Force: Theoretical Considerations
szekel 43677 20
How can you calculate the rotation angle needed to tighten a bolt to a specified clamping force?
In theory, you can calculate it from the bolt’s torque/friction, its elastic stretch, and the thread pitch, but in practice the result is only approximate because friction under the head and in the thread varies a lot. First determine the tightening torque as the sum of thread-friction torque and bearing-surface friction torque, then solve for the tensile force F; after that use Hooke’s law to get the elongation Δl = (l·F)/(S·E), and finally convert elongation to angle with φ = Δl·360°/P [#17824599] One example given for an M10 bolt, l = 100 mm, torque 100 Nm, friction coefficient 0.1, and E = 210 GPa produced about F = 68,041 N, Δl = 0.62 mm, and roughly 149° of turn [#17826994] The angle should be counted only after slack is removed and the bolt starts resisting by hand, not from the free-running start [#17823455] The method is used in machine design and even in head tightening, but it depends on average values for diameters and friction coefficients, so lubrication, dirt, surface type, and thread condition can change the real result significantly [#17826508][#17828562]
  • #1 17823383
    szekel
    Rate: 9
    Is it possible to calculate the angle by which the key should be turned so that the bolt is tightened with the appropriate force? It seems so, because the same bolt, in the same place, will always have a constant angle corresponding to some force. Unless, of course, the thread is not damaged, because then, of course, the screw will no longer have the factory properties.
    How is it calculated? What data do you need for this? Maybe there are just some calculators for this?
    I know that's what torque wrenches are for, it's just a purely theoretical question.
  • #2 17823455
    qbis19
    Help: 20
    Rate: 64
    Such calculations are used, for example, when tightening the head at the last stage. Of course, without a torque wrench, it will not be possible, and with the wrench itself, it will not be possible, because the greater the tightening force, the greater the friction on the thread and between the head and the material. This friction can be different for e.g. 10 head bolts. Therefore, the last stage of tightening is performed at a given angle and in practice it looks like that some bolts go relatively light and e.g. the bolt next to it goes hard. If you used a torque wrench for this, the first bolt would work properly, but the second bolt might not even twitch. Just the angular tightening might make sense under ideal conditions, but how would you know where to start counting the angle? :)
  • #3 17823468
    szekel
    Rate: 9
    When the bolt begins to resist tightening by hand ;)
    Of course, we are talking about a fairly clean thread.
    Either way, ideally there must be an angle suitable for the given force. How to calculate it? I am very curious about it, besides, it can be useful for emergency tightening when the torque wrench is not available.
  • #4 17823611
    nightdrivers
    I really don't know what you're up to and why you're making your life difficult :D
    It is difficult to create ideal conditions for all sockets in the head and the screws for them
    That is why someone came up with a torque wrench and manufacturers of seals additionally recommend angular tightening so that the assembly process is performed as precisely and evenly as possible, e.g. head ;)
    If you want so much, maybe do it by observation, tighten the screws with different strength and keep notes on the observation how many degrees the key will turn at 10, 20, 30 Nm and so on and you will have your pattern voluntarily speaking :D
    But in my opinion there will be discrepancies with different thread diameters, but maybe I am wrong :O
  • #5 17824599
    marszałekkom
    Help: 212
    Rate: 510
    Well, yes and no.
    The screw tightening torque is the sum of the two friction torques: friction on the threads and friction of the screw head against the bearing surface. Thread friction:
    Mt = 0.5 * ds * F * tg (? + ? ')
    where ds - mean thread diameter, F - tensile force of the bolt, ? - helix angle of the bolt and ? 'is the apparent friction angle in the thread. how to calculate it, I can give you a formula later if you are interested, but you probably won't.
    Now the friction on the shoulder surface - and here is the problem, because it depends on what surface. It is different for the surface of the ring washer, different for the circular washer, and different for the conical washer. In addition, various sources provide different information, but e.g. for a ring washer or a collar of a nut, the formula looks like this:
    Mt = 0.25 * (Dp + dp) * F * u
    where Dp - outer diameter of the washer, dp - internal, F - tensile force of the bolt, and u is, of course, the friction coefficient.
    Now, knowing these two formulas, you can determine the tensile force F from them. And this force results directly from stretching the bolt while tightening - because, for example, one turn of a bolt by 360 degrees means stretching it by the length of one thread pitch. And now, if you know this force F, then from Hook's law you determine the extension of the bolt ?l:
    ?l = (l * F) / (S * E)
    Where l is the original length of the bolt, F is the force you determined it a moment ago, S is the cross-sectional area of the bolt - but on the inside diameter, i.e. measured at the bottom of the thread - and E is the Young's modulus for the bolt material. And once you know ?l, you know that you will calculate it from the thread pitch P and the rotation angle you are asking for.
    ? = ?l * 360 ° / P
    What's the catch in all of this? Well, all these diameters, angles and, above all, the coefficients of friction are average and approximate values. We never really know how much force was put into the friction. Lubricate one bolt with oil more, another less, sometimes some dirt will come up, etc. And the more you tighten, the greater the discrepancies.
  • #6 17825077
    qbis19
    Help: 20
    Rate: 64
    I've been waiting for that ending :) .
    All formulas and calculations, not only average, but also prove themselves in laboratory conditions. Here, even the temperature matters. Such an exemplary pad may be of different materials or covered with different materials. The screws may not have a perfect thread as well. Some may be "tighter" others not, and then we have different friction surfaces. It could be like that for a long time :)
  • #7 17826508
    marszałekkom
    Help: 212
    Rate: 510
    No, it's not just such fairy tales. It is from these dependencies that various diameters, thread lengths, tightening torques, etc. are calculated in the construction of machines. Only that in factories with factory-new elements, the conditions are more similar to theoretical ones. And of course, the fact that the washer is made of a different material does not matter, you just need to have tables with friction coefficients for different material configurations.
  • #8 17826521
    szekel
    Rate: 9
    @ marshals and could you show a simple example based on these formulas? And what are the constants 0.5 and 0.25?
  • #9 17826778
    darfur5
    Help: 267
    Rate: 1715
    If I had to decode the patterns while tightening the head and feel the customer's breath on my back ... I would rather buy a dynamometer (it's not a big cost), use the vehicle manufacturer's instructions and that's it.
  • Explaining the 0.5 and 0.25 torque constants
    #10 17826994
    marszałekkom
    Help: 212
    Rate: 510
    For example, tighten an M10 bolt with a length of l = 100 mm using a torque of 100 Nm. Let us assume that the bolt presses directly with its head against the friction surface, the dimensions of the friction surface for a standard M10 bolt with a key 17: Dp = 17 mm, dp = 11.2 mm. We take the coefficient of friction 0.1 and the Young's modulus 210 GPa.
    Such a screw has a pitch P = 1.5 mm and an average thread diameter ds = 9.026 mm. The tangent of the helix angle is:
    tg? = P / (? * ds) = 0.0529
    hence
    ? = 3.025 °
    Apparent friction angle tangent:
    tg ? '= u / cos30 °
    30 °, it follows that it is half the angle of the metric thread, such a surface is affected by the frictional force in the thread.
    tg ? '= 0.1155
    ? '= 6.589 °
    Having these two slightly abstract parameters, we transform the formula into the moments of friction so as to determine the tension force for the bolt. It's a bit hard to write formulas here so I'll give you the result right away:
    F = 68,041 N
    A standard M10 bolt has a cross-sectional area of S = 52.266 mm?. E = 210 GPa, while the length l = 100 mm, let's assume that this is only the length of the tensile part. From Hook's law:
    ?l = 0.62 mm
    So if:
    ? = ?l * 360 ° / P
    then for ?l = 0.62 mm:
    ? = 148.8 °
    So you only need to turn the screw almost 150 degrees. Except that it is 150 ° of pure stretch, i.e. when the slack is removed, the dirt is out, etc. Also note that we stretch 100 mm of the bolt by only 0.6 mm, and such a small stretch causes a force of over 68 kN, which is almost 7 tons . In fact, this force is so great that even a 10.9 bolt would not hold out, I should have taken the M12 as an example, but I did not want to count again.
    The constant 0.5 means half, because the torque is the force multiplied by the radius on which the force acts, and the radius is half the diameter. In this case, the diameter is ds, and half of ds is 0.5 ds. However, 0.25 is half of a half, which results from the calculation of the mean radius of the washer, which is half the distance between the outer diameter Dp and the inner dp, and the radius is half the diameter .
    Oh, maybe I made a mistake, I learned it a long time ago, and if there is any constructor here, let him check me.
  • #11 17827293
    qbis19
    Help: 20
    Rate: 64
    I admire you felt like it, but this is valuable information for the inquisitive :) .
    Coming back to the head for a moment. "Today's" screws have a special design. I do not know, I did not go into detail, but they cannot be used a second time because they are stretched "screw flows" during tightening, and reusing them may break.
  • Bolt preload loss from long-term stress relaxation
    #12 17828536
    marszałekkom
    Help: 212
    Rate: 510
    It's not just today, they all have it. Even in Sam, I repair a Mercedes 190, a car from the early 90s, it is written to measure the bolts before assembly and if they exceed a certain length, replace it. The point is, you stretch an element within acceptable limits, within an elastic range, and then expose it to a high temperature, but still much lower than the softening point of the material. And although there is neither high stress nor high temperature, after a few years in such conditions, the elastic stress disappears - the bolt ceases to tighten the screwed elements. Therefore, among others the gaskets under the head let go.
  • #13 17828562
    kortyleski
    Help: 957
    Rate: 3860
    All calculations are cool and true, but there is an assumption that twisted materials do not deform. Unfortunately, this is not the case.
  • #14 18689328
  • #15 18689424
    Megawe
    Help: 246
    Rate: 1438
    "Mechanics" from pegs turn large engines without a torque wrench and somehow the Ursus and Zetors worked.
    It was worse when a Perkins engine hit their paws. In English instructions, they give two different head tightening torques for one motor, depending on the material from which the bolts are made. Overall bolts are identical, only the material is different and the problem is how to recognize what material these bolts are made of.
    Tightening the head with a torque wrench makes the bolts that are tightened last on the circumference compress the head more tightly than those that were tightened first. As someone understands it, then the bolt tension is evened out, especially on the soft head gaskets.
  • #16 18689445
  • #17 18689457
  • #18 18689476
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    I always have freaks when tightening the head screws. Especially the long threads, although I dip them in oil, I give the YATO key for legalization every year. I tighten the bolts in sequence, about four times, and you will still get one of two that it goes slightly easier, as if the thread is loosening.
  • #19 18689477
  • #20 18690103
    Mierzejewski46
    Level 37  
    Help: 339
    Rate: 1069
    I bought my first torque wrench when I had to repair a Polonaise with a 1.4 Rover engine. Plastic construction, long head bolts. I twisted one, it puffed like a carrot, and then I understood what tightening torques were. Previously, it was probably a good chunk (felt) and it was spinning. You can feel when the screw springs up and the thread no longer pulls. The old engines were much more tolerant.
  • #21 18694696
The discussion revolves around the theoretical calculation of the wrench rotation angle required to achieve a specific bolt tightening force. Participants highlight the complexities involved, such as the influence of friction on threads and surfaces, which can vary significantly between bolts. Various formulas for calculating torque and friction are presented, emphasizing the need for ideal conditions to achieve accurate results. The conversation also touches on practical experiences with torque wrenches, the importance of following manufacturer specifications, and the challenges faced when tightening bolts in real-world scenarios. Observational methods and empirical data collection are suggested as alternatives for those without access to torque wrenches.
TL;DR: With known thread data, you can estimate tightening angle from torque. Example: 100 Nm on an M10 yielded ~68 kN and ~149°. "You only need to turn the screw almost 150 degrees." Friction variability limits accuracy. [Elektroda, marszałekkom, post #17826994]
Why it matters: For DIY mechanics, bike techs, and engineers who need to calculate or approximate bolt preload and angle without over/under‑tightening when tools or specs are missing.
How do I calculate the wrench rotation angle for a target bolt force?
Model torque as the sum of thread friction and underhead friction. From the applied torque, solve for preload F. Compute bolt extension using Hooke’s law: Δl = lF/(SE). Convert extension to rotation with the thread pitch: θ = Δl·360/P. This assumes known geometry and friction. [Elektroda, marszałekkom, post #17824599]
What data do I need before calculating angle from torque?
You need thread pitch P and mean diameter ds. Get helix angle from P/(π·ds) and apparent friction angle from μ/cos30°. Measure washer diameters Dp and dp. Know the tensile length l, core area S, and Young’s modulus E. Estimate friction coefficient μ for the specific materials and lubrication. [Elektroda, marszałekkom, post #17824599]
Can I start counting angle when the bolt first resists by hand?
Not reliably. First resistance varies with dirt, lubrication, and seating. Without a defined snug point, the angle origin drifts. As noted, “how would you know where to start counting the angle?” Start only after slack is removed. [Elektroda, qbis19, post #17823455]
Is torque‑to‑angle better than torque alone?
Use torque‑to‑angle after an initial torque stage when bolt friction varies. It helps equalize clamp across multiple fasteners. Some bolts turn easily while neighbors feel hard at the same torque. Angle staging drives the same additional stretch. [Elektroda, qbis19, post #17823455]
Worked example: What angle for an M10 at 100 Nm?
For an M10 with μ≈0.1 and E≈210 GPa, preload computes ≈68 kN. The bolt extends ≈0.62 mm over 100 mm. With P=1.5 mm, rotation after seating is ≈149°. “You only need to turn the screw almost 150 degrees.” [Elektroda, marszałekkom, post #17826994]
Why do equal‑torque bolts feel different while tightening?
Friction varies at the threads and under the head. One bolt may be cleaner or better lubricated than the next. “Some bolts go relatively light and the bolt next to it goes hard.” Torque alone can stall a sticky bolt prematurely. [Elektroda, qbis19, post #17823455]
Do these calculations work outside the lab?
They guide design, but reality drifts. Temperature, coatings, and thread quality shift friction and preload. As noted, “All formulas and calculations... prove themselves in laboratory conditions.” Treat results as estimates unless surfaces and lubrication are controlled. [Elektroda, qbis19, post #17825077]
What if the clamped parts deform or settle?
Calculations assume rigid parts. In practice, gaskets, flanges, and threads deform and settle, changing preload. That reduces accuracy and may require re‑torque or a different joint design. [Elektroda, kortyleski, post #17828562]
How should I tighten a cylinder head to keep gasket load even?
Follow the specified order and stages. Tighten in sequence so compression spreads evenly. A final angle stage after torque helps equalize bolt stretch. Otherwise, the last bolts tightened can compress the head more. [Elektroda, Megawe, post #18689424]
Should I reuse head bolts after removal?
Many modern head bolts plastically stretch during torque‑to‑yield procedures. Reusing them risks low preload or breakage. Replace when specified rather than reusing. Check the manual for single‑use guidance. [Elektroda, qbis19, post #17827293]
How can I approximate angle without a torque wrench?
How‑To: emergency angle approximation
  1. On a similar joint, tighten to known torques (e.g., 10, 20, 30 Nm) and record resulting angles.
  2. Mark a reference line on the bolt and part for consistent angle reading.
  3. In a pinch, seat the joint, then apply the recorded angle to reach the target torque. [Elektroda, nightdrivers, post #17823611]
What are typical bicycle torque values for cranks and cassettes?
Typical values: cranks around 60 Nm and cassettes around 40 Nm. Use a torque tool when possible to protect alloy parts and hubs. [Elektroda, Anonymous, post #18689328]
What do the 0.5 and 0.25 constants in the formulas mean?
They convert diameters to effective radii. Torque equals force times radius, so 0.5·d is the radius. The 0.25 factor is the average bearing radius from inner and outer diameters, i.e., half of a half. [Elektroda, marszałekkom, post #17826994]
Which tools improve tightening accuracy?
Use a calibrated torque wrench and keep threads clean and lightly oiled as specified. Users report annual calibration of tools like YATO wrenches. Multiple passes in sequence can settle joints before the final pass. [Elektroda, Mierzejewski46, post #18689476]
How do friction and lubrication change torque‑to‑tension accuracy?
Friction dominates torque usage. Higher μ needs more torque for the same preload, increasing scatter. “Lubricate one bolt with oil more, another less,” and preload changes at identical torque. Expect errors to grow as tightening force rises. [Elektroda, marszałekkom, post #17824599]
