Tightening M10x35 Bolt: Proper Torque 30 Nm + 90 Degrees Explained for Beginners
witek567 71940 17
How do I tighten a bolt specified as 30 Nm + 90 degrees?
Tighten the bolt first to 30 Nm with a torque wrench, then turn it an additional 90° (a quarter-turn) with a wrench; if the procedure lists multiple angle steps, do them in that order. [#12139711] This is not “by hand” tightening without tools, because 30 Nm is already a specific torque and the 90° part is an extra angle-tightening step. [#12139802] The extra 90° is generally used as a supplementary tightening method for more accurate clamping, though one reply notes that for a shock absorber it may be more than necessary and the specified torque for the bolt size/type is the important part. [#12142692]
  • #1 12139675
    witek567
    Rate: 31
    Hello, maybe a little stupid question, but everyone started out once, which means that the M10x 35 bolt must be tightened with a torque of 30 Nm + 90 degrees. I know that you need to set this value on the key, there is no problem here, but what is it with + 90 degrees? Thank you in advance for your answer.
  • #2 12139711
    Aleksander_01
    Help: 1167
    Rate: 3435
    You tighten a given bolt or nut by 30 Nm and then with any set wrench you tighten it by an angle equal to 90 °.
    They usually say how to tighten the head
    1. 20 Nm
    2.90 °
    3.90 °, i.e. first with a dynam key. 20 Nm and then two times 90 ° (the order still applies).
  • #3 12139720
    Błażej
    Help: 1923
    Rate: 3627
    Sometimes the time between consecutive steps is also given.
  • #5 12139760
    witek567
    Rate: 31
    Exactly what I mean is tightening this shock absorber Link , i.e. I have to tighten it with a force of 30 Nm and then turn the ordinary key 90 degrees?
    Do I have to tighten it with a torque wrench? Can I tighten it normally by hand? What are the consequences of a normal hand tightening of a shock absorber?
  • Use a torque wrench before the 90-degree turn
    #6 12139802
    Aleksander_01
    Help: 1167
    Rate: 3435
    Man, you know what you write, you know what 30 Nm is with such a short arm, here New Year's Eve with Arnold will not be able to screw it without keys.
    Either do not do it because I see you overwhelmed, or do as they say.
    These 90 ° are any key with a fairly long arm.
  • #7 12139814
    witek567
    Rate: 31
    @U.P.
    That's why I meant it, because I don't know whether to buy this key, whether this 30Nm value is large or not, so it turns out that I have to buy a key.
  • Recommends using a torque-angle wrench for bolt tightening
    #8 12139857
  • #9 12139925
    Aleksander_01
    Help: 1167
    Rate: 3435
    giepetto wrote:
    So that this key is not more expensive than the exchange service :D
    Invite someone who did anything mechanic, tighten these bolts without any dynamometers ...
    I agree with the first sentence, but the second is typical mechanical ignorance.
  • #10 12139991
  • Recommends tightening shock absorber mounts by feel
    #11 12140267
    dan1974
    Hello, as for your considerations, I will write how I do it I-the upper part of the shock absorber attachment (the attachment, the extension is a ratchet and max with feeling-I suspect that you will not break, and will not unscrew) the bottom will be the same and it will be a git-trust me there are no direct forces so they won't unscrew
    and as for Arnold, you have a force of 30Nm in your hand and a normal rattle
  • #12 12140505
    Aleksander_01
    Help: 1167
    Rate: 3435
    You know what kind of "pair" he would have to have in his hands, read his post with understanding, he wanted to screw it on with his bare hand, and then what arm do you have - a centimeter, two.
  • Clarifying shock absorber torque and 90-degree tightening
    #13 12140596
    dan1974
    you think it's literally about tightening with your hand - or a wrench in your hand
    let's wait for the answer of the questioner
  • #14 12141281
    witek567
    Rate: 31
    Of course I meant that I would tighten these bolts with a regular wrench, not my hand :) So there has to be this torque wrench in the end? Because there are different opinions.
    EDIT
    One last question, is it necessary to converge after installing new shields?
  • #15 12142453
    dan1974
    You know what kind of "pair" he would have to have in his hands, read his post with understanding, he wanted to screw it on with his bare hand, and then what arm do you have - a centimeter, two. [/ Quote]
    you are quite a reader with understanding: -;
    there is no need for toe-in since these are the rear shock absorbers
    tighten the screws to the max and go
  • Specified torque is sufficient for shock absorber bolts
    #16 12142692
    mczapski
    Level 40  
    Help: 468
    Rate: 1659
    It is clear that everything can be complicated. In the initial question, the colleague is basically ready to carry out the exchange but needs an explanation of the mechanism. So the necessity to tighten to the specified torque leaves no doubt. Worse with complementary tightening by 90. And I think the instructions are a bit reimagined for these needs. As this is the principle he applies to screws with high accuracy working under cyclic loads (theoretically a shock absorber does). In theory and sometimes in practice, assumed deformations of the bolt and the friction surfaces are introduced during this supplementary tightening. The value is determined experimentally and it is difficult to determine the value of the moment due to changing conditions. In the case of a shock absorber, however, it is a bit of a form overgrowth with content and it is enough to tighten with the specified torque, appropriate for the size and type of the bolt.
  • 30 Nm plus 90 degrees is excessive
    #17 12142957
    Aleksander_01
    Help: 1167
    Rate: 3435
    To dan1974 - if someone writes "normally with his hand" instead of writing with "normal wrench" then I understand it with the same hand, just like tightening the oil filter, initial bolts, nuts.
    In the mechanical vocabulary, there is such a concept as "by hand", ie without the use of any tools.
    Or maybe the guy is some kind of titan and tears with his bare hand 18.
    As for using the dyn. I always use it for: spark plugs and glow plugs, injectors, cylinder head.
    These 30 Nm + 90 ° is fucking .. a lot.
  • #18 12143114
    Mazda2500
    Rate: 10
    You will buy a head gasket there, you have everything written there. I have 26Nm and 2 times 90 degrees in my own. But if you have never done it, do not even do it. Then you have to screw the shafts, adjust the timing and do a lot more. It blows you in a few km. Give the car to the mechanic because I see it in black.
The discussion revolves around the proper method for tightening an M10x35 bolt to a torque of 30 Nm followed by an additional 90 degrees. Participants clarify that the initial torque should be applied using a torque wrench, and the subsequent 90-degree turn can be done with a regular wrench. There is debate about the necessity of using a torque wrench, with some suggesting that it is essential for accuracy, especially for components like shock absorbers that experience cyclic loads. Others argue that practical experience can suffice, but caution is advised for those unfamiliar with the process. The importance of following specified torque values to avoid mechanical failure is emphasized, along with the suggestion to consult service manuals for specific torque requirements.
