I can't connect the decoder to the internet via the wifi module
Seba12123 12180 4
  • Green LED on but wifi module not detected
    #1 17021338
    Seba12123
    Hello :) I have a small problem, a month ago I was connected to my second window to the world and more specifically I founded digital Polsat. Everything is beautiful, I can't connect to the internet via wifi, I bought the module, I connected everything as recommended by Cyfrowy Polsat, but my module does not detect wifi :( the message "network not found, check if your module is a link is connected to the decoder" pops up, the problem is that it is not found, the green LED is on all the time. I am begging you for help !!!
  • #2 17021353
    leonov
    Help: 1039
    Rate: 2251
    Seba12123 wrote:
    I bought the module
    What module ??
    Seba12123 wrote:
    I connected everything as Digital Polsat recommends
    I mean, how did you connect it, what about what with what? what decoder?
  • #3 17021474
    Seba12123
    I connected the usb cable and ethernet pvr bd 7000 decoder
    Added after 8 [minutes]:
    And the module is TP-Link TL-WR702n
  • #5 17022116
    Seba12123
    It works ! Thank you very much :D I put a brewery for it :D
