HD5000 - Cyfrowy Polsat at a hotel in the Netherlands - how to set up?
adys92 7299 10
Jak podłączyć dekoder Cyfrowego Polsatu HD5000 w hotelu w Holandii, jeśli w gniazdku TV/Radio nie ma sygnału satelitarnego?
Nie uruchomisz tego dekodera z gniazdka TV/Radio, jeśli hotel nie ma doprowadzonego sygnału satelitarnego — HD5000 potrzebuje anteny satelitarnej ustawionej na odpowiedni kierunek [#17077963][#17078587] Musisz sprawdzić w hotelu, czy z gniazda opisanego jako TV wychodzi sygnał z anteny satelitarnej, a nie z kablówki albo telewizji naziemnej [#17077844][#17077875] W typowym gnieździe TV/Radio jest tylko telewizja naziemna, więc dekoder Polsatu nie pokaże obrazu [#17077963] Jeśli hotel nie ma instalacji satelitarnej, nic nie zrobisz samym podłączeniem do tego gniazda [#17078587]
  • #1 17077817
    adys92
    Hello. I work and live in the Netherlands at the hotel. While in Poland on vacation I bought a decoder at Cyfrowy Polsat. I just wanted to have TV here in the Netherlands. The gentleman in the salon sworn that he would take it because people use it.
    Well, I have a problem the HD5000 decoder. When everything is connected there is no preview signal.
    The hotel has a socket with 2 outputs. Signed TV and RADIO.
    I connect the antenna cable to the TV and to the decoder. The decoder is connected to the TV with an HDMI cable. I will add that today it was unpacked and connected for the first time.
    I have not called the hotline anywhere yet.
    Please help.
  • #2 17077844
    trajmund
    I will ask yes. Are you sure that the connection in the socket described as TV is the connection from the satellite dish and not e.g. from the cable TV?
  • #3 17077851
    maksar
    Help: 177
    Rate: 1030
    Who guaranteed you that the antenna in the Netherlands is set to HB
    adys92 wrote:
    take because people use.
    As they set up their own antenna, they use it.
  • #4 17077875
    Pan.Kropa
    Help: 252
    Rate: 1178
    Just don't say you're out of the country. You must find out if there is a satellite signal available at this hotel socket.
  • #5 17077883
    maksar
    Help: 177
    Rate: 1030
    trajmund wrote:
    that the socket connection described as TV
    The connection is usually energy.
  • #6 17077944
    trajmund
    Well, I understand. This is what this connector or connector is called correctly because I don't know. I just wrote back just like that. I don't understand clinging to words.
  • #8 17077963
  • #9 17078157
    adys92
    So I can't do anything?
    However, it is probably terrestrial.
  • #10 17078202
  • #11 17078587
    andpol 33
    Help: 513
    Rate: 1146
    If the socket is TV and Radio, it is known that there is no satellite. You have your own antenna, which they probably won't let you hang.
The discussion revolves around setting up a Cyfrowy Polsat HD5000 decoder in a hotel in the Netherlands. The user is experiencing issues with no signal after connecting the decoder to the hotel’s TV and radio socket. Responses indicate that the hotel likely provides a digital terrestrial television signal rather than a satellite signal, which is necessary for the HD5000 to function. Users suggest verifying the type of connection available at the hotel and confirm that the socket labeled "TV" may not be connected to a satellite dish. The consensus is that without a proper satellite antenna, the decoder will not work as intended.
