  • #1 17023419
    CezarII
    Hello, I'm new here but I hope to stay here. I have a question for you, is it possible to build an arc reactor in a form similar to iron man? But its end would not be plugged in with a cable, but more screwed / put into a "pocket" in which it would transmit some sensible power to a socket in that "pocket"? This question is general whether such a thing would be real at all.
  • #2 17023441
  • #3 17023547
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    CezarII wrote:
    Hello, I'm new here, but I hope to stay here.
    Welcome
    Yes in form, no in action.
    http://joemonster.org/art/27612
    I guess birdie. And he did not upload, only download ;)
    It is as real as the source of your inspiration.
    You have "Utility Electric" in the caption, maybe it's worth changing "utility" to something less confusing? ;) Exotic?
    Sorry, this is a typical tech forum, so you can joke about such ideas. I didn't mean to discourage you.
    You probably don't have physics in school yet, and you don't know that there are things shown in movies that aren't possible in the real world.
  • #4 19095329
    Naukowiecelektro
    It can be, but it needs to be transformed a bit and it is real ready
  • #5 19095822
    Jawi_P
    Level 36  
    Help: 260
    Rate: 715
    Well, I'm waiting for further explanations, materials, etc. Because you probably won't stop there?
  • #6 19095870
    thereminator
    Conditionally unlocked
    Help: 219
    Rate: 657
    And don't you want an enchanted pencil?
  • #7 19096026
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3350
    There were electrodes in the shop :D
    Arc reactor, would it be feasible?
  • Arc reactor described as buildable but far off
    #8 19605229
    Norbi007c
    I know the topic is old, but I think nothing will happen if I answer :P
    The Arc Reactor is a perpetual motion machine that is an infinite source of energy. In the movie, he could run forever if nothing is using his power, in the case of Tony Stark's armor is powered by this reactor and she takes a lot of power from the reactor, but the reactor is able to handle it easily, because the first one of his the version produces 3 GJ / S (three gigajoules per second), the later, improved versions produce more power. For example, if Tony had been flying his armor all day without interruption, the reactor would eventually collapse, or the power he would produce would have dropped by higher draw.
    Is this reactor buildable? of course it is, but it will be a long time before a person can create such a source of energy.
  • Fusion fuel still requires impractically large mass flow
    #9 19605443
    Madrik
    Help: 627
    Rate: 1191
    Energy is not "produced", it is transformed.
    Any fuel used is actually energy in material form.
    Wind, hydro or solar power plants - they use the energy of the surrounding environment.
    If you were to use, for example, uranium as fuel - it would consume about 2 grams per minute, i.e. you would need almost 3 kilograms per day.
    It is possible that nuclear fusion could be used, 1 gram of matter would be enough for ... 5 minutes of work. This is only about a 10-fold increase in capacity, so the fusion reactor would need about half a kilogram of fuel a day.
    And we're talking about a technology that doesn't really exist yet.
    Although ... if you had used, for example, air as fuel for nuclear fusion ... those few cubic meters would give you enough mass to get the energy you need.
    But is the annihilation of the air around you ... really a good idea? :D
  • Speculation on unknown energy forms for electron flow
    #10 19623626
    jakubmaternowski
    200 years ago we had no idea that electricity existed. Someone finally forced the flow of electricity. Then, electromagnetic waves were artificially created. They are possible, but people are too limited as individuals to jump that border in one generation. If we assume that the Big Bang really led to the creation of the universe, it released a lot of energy, the density of matter decreases, then by converting matter into energy according to Einstein's emc, we get energy. But it is still unknown whether we already know all its forms that exist in our dimension of consciousness. Maybe it is enough to catch a new unknown form and force it to cause the movement of electrons.
  • #11 19623832
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4258
    As far as I remember correctly, 3/4 of the mass of the universe is an unknown form of energy. But she does not move electric charges - if she did, she would have been known long ago ...
    Norbi007c wrote:
    its first version produces 3 GJ / S (three gigajoules per second)
    With such power, one could accelerate to Cosmic I in a second, with an acceleration 800 times greater than the gravitational one on Earth ...
  • Dark matter may be a model mismatch, not unknown energy
    #12 19625694
    Madrik
    Help: 627
    Rate: 1191
    Actually, you don't know what it is. It's just that calculations made by known models of the universe don't match. This means that either our models are not accurate and consistent with the facts, or we do not know something.
    The latter option has been chosen and scientists are trying to find what we do not know yet, instead of building new models according to different patterns (which we do not have and do not know either). It might as well be something well-known that our current tools simply cannot detect, so they detect "nothing". Hence, a calculation error may arise.
  • #13 19626072
    _jta_
    Help: 3212
    Rate: 4258
    It can be an additional constant (the so-called cosmological constant ) in Einstein's equations. She gives such input as energy. Einstein proposed it when it turned out that the universe cannot be stable without it - then it was discovered that the universe was expanding and Einstein mistaken it, and then it was discovered that without it the calculations did not match.
  • #14 19830784
    zielinskikuba68
    you could use the method like in Chernobyl but after 1 radiation and after 2 you will not get such materials. Regards
  • #15 19830813
    tos18
    Help: 1113
    Rate: 1870
    Look for the book In Search of Unlimited Energy
    Keith Tutt
  • Mercury and copper coil experiment proposal
    #16 19830844
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Energi of point 0. It is this black part of the universe, it is known about it, but it is not obtained because it has a bad influence on our world. They were in the 50's experiments. And 40 theses, but blue-eye and pink fanatics ....... have been examining it and it's not good to write about it.
    Added after 53 [seconds]:
    If you have 200 kg of mercury in stock, we will experiment. I do the copper coils.
  • Antimatter arc reactor claim is physically impossible
    #17 20065404
    ironmankochamcie
    I have an opinion on this subject confirmed by facts and also by the laws of physics. Tony Stark's Arc Reactor could be built today! It would be enough to use anti-matter as the main fuel, and then change the meaning of the phrase "perepeetum mobile", because it would not be possible anymore. It would be enough to create the above-mentioned arc reactor from anti-matter. How to do it, you ask? Very simple. a piździk what connects it to the phone and recharges this phone. present if I had as much hay as he. The conclusion is that everyone can and who does not try this moron could be made an arc reactor as the above sentences said, but you need hay, and if there is no hay, you need to call the stork, i.e. Elon Muska, because she has a lot of money of this type. If he gave me half, he would not even feel it. You have to call him and involve him in creating IRON MENA. Peace. Bedoesiar with you. Your Dear Friend. Loyal Joe.
  • #18 20065471
    Help: 1405
    Rate: 6430
    ironmankochamcie wrote:
    I would have been a present-day Putin long ago if I had had as much hay as him.
    If you would do it, you would have the entry of the self-appointed elite of this world and the electrophile account would also disappear.
    Realize finally that pinheads mean nothing, and only widely announced discoveries will have their raison d'?tre, otherwise they will be bought up by the foreskin negative and will end up in drawers.
  • #19 20065518
    _jta_
    Help: 3212
    Rate: 4258
    It is expensive to produce (requires much more energy than can be obtained) and difficult to store.
    It's good that you don't have one - one such thug who threatens the whole world and will probably kill millions of people, that's too much.
  • Antimatter proposal ignores conservation of energy
    #20 20065853
    Madrik
    Help: 627
    Rate: 1191
    And will you reveal which "laws of physics" you follow? Because we, for example, the Principle of Conservation of Energy.
    It would be enough to use anti-matter as the main fuel, and then change the meaning of the phrase "perepeetum mobile" because it would no longer be impossible.
    This is called the paradox - the mental suspension of the laws of physics for a thought experiment. Only that "perpetual motion" is such a paradox. It breaks one of the fundamental principles of physics to describe a non-existent object.
    And "perpetual motion" doesn't exist, not because the definition is wrong, but because you can't break the laws of physics.
    It would be enough from anti-matter to create the above-mentioned arc reactor. How to do it, you ask? Very simple. All you need to do is connect this little puff that connects it to the phone and recharges this phone. And then, when we have a charged powerbank, we connect it to the battery and force anti-matter into it.
    And the doctor, what time does his ward tour start? Have you taken your medication yet?
    Seems simple, there's just an idiot not to do it.
    You don't seem to have done it yet?
    Bedoiara with you. Your Dear Friend. Loyal Joe.
    Sorry, we don't understand Klingon. Try Earthly - we have 7,000 languages to choose from.
The discussion revolves around the feasibility of creating an arc reactor similar to that depicted in the Iron Man franchise. Participants express skepticism about the practicality of such a device, citing it as a perpetual motion machine that defies the laws of physics. Some responses suggest that while the concept is intriguing, it remains largely theoretical and would require advanced technologies, such as nuclear fusion or antimatter, which are not yet fully realized. The conversation touches on energy transformation, the limitations of current scientific understanding, and the potential for future breakthroughs in energy generation.
TL;DR: 3 GJ/s would consume about 2 g of uranium per minute; "Energy is not 'produced', it is transformed." An Iron Man arc reactor stays fiction; only cosmetic props or low-power wireless couplers are realistic today. [Elektroda, Madrik, post #19605443]
Why it matters: This FAQ helps makers, students, and curious readers separate sci‑fi from safe, buildable options and pick realistic wireless‑power paths for projects.
  • Movie-scale 3 GJ/s output implies ≈2 g/min uranium fuel and extreme heat rejection—non‑portable power and thermal management. [Elektroda, Madrik, post #19605443]
  • Qi wireless power delivers about 5–15 W at close range with alignment and foreign‑object detection to limit heating. “Qi wireless power standard”
  • SAE J2954 standardizes ~3.7–11 kW EV wireless charging pads with alignment and safety controls. “SAE J2954 standard”
  • Matter–antimatter annihilation yields ~1.8×10^14 J per gram pair; production and storage remain impractical. “NASA Glenn: Antimatter Propulsion”
  • No commercial fusion power plants exist yet; handheld fusion reactors are not an engineering option today. “IAEA: Fusion Energy”
Is an Iron Man–style arc reactor physically possible with today’s science?
Functionally, no. “Yes in form, no in action.” Energy sources must obey conservation and require fuel, conversion, and heat rejection. You can build a look‑alike prop, but a palm reactor delivering gigawatts violates practical physics and engineering constraints. [Elektroda, Jawi_P, post #17023547]
Could I build a chest‑worn unit that wirelessly powers a device in a pocket?
Yes, at low power. Use inductive (Qi‑class) coils for a short‑gap link to a receiver in the pocket. Expect 5–15 W, close alignment, and thermal limits. Foreign‑object detection helps cut power if metal heats. Keep batteries and coils off skin or add insulation. “Qi wireless power standard”
How much power can consumer wireless charging safely deliver through clothing?
Plan for single‑digit watts to about 15 W. Qi requires close coupling; extra distance or misalignment reduces efficiency and raises heat. Thin fabric is more forgiving than thick layers. Monitor temperature, enable foreign‑object detection, and derate power for comfort and safety. “Qi wireless power standard”
What about transferring kilowatts wirelessly like in EV charging?
That exists for cars, not wearables. SAE J2954 standardizes 3.7–11 kW pads with alignment and control to constrain stray fields. The coils, shielding, and thermal hardware are large and floor‑mounted, so they are unsuitable for body‑worn devices. “SAE J2954 standard”
Why can’t we use antimatter to power a wearable reactor?
Antimatter has enormous energy density (~1.8×10^14 J per gram pair), but production rates are tiny and storage needs complex electromagnetic traps. Handling and containment are incompatible with a pocketable, safe device. It’s not a near‑term engineering path. “NASA Glenn: Antimatter Propulsion”
Could fission or fusion fit in a palm‑sized reactor?
At 3 GJ/s, fission would burn ~2 g of uranium per minute and demand heavy shielding and heat rejection. Fusion at that output would still require significant fuel and technology that does not yet exist for compact systems. [Elektroda, Madrik, post #19605443]
Is zero‑point or dark energy a realistic power source here?
No. These concepts reflect gaps between observations and models, not usable engineering energy sources. We lack an agreed mechanism or technology to extract such energy, so it provides no practical design basis. [Elektroda, Madrik, post #19625694]
What does “energy is transformed, not produced” actually mean?
You always convert one form of energy into another: chemical, nuclear, thermal, or electromagnetic. Generators, reactors, and batteries transform energy; none create it. As one expert put it, “Energy is not ‘produced’, it is transformed.” Size your source, conversion stage, and heat path accordingly. [Elektroda, Madrik, post #19605443]
How big is “3 GJ/s” really?
It’s 3 gigawatts—rocket‑class power. As noted, with such power you could reach orbital speed in about a second, at roughly 800 g acceleration. That scale illustrates why pocket devices are out of scope. [Elektroda, jta, post #19623832]
How can I prototype a safe, look‑alike “arc reactor” for cosplay?
  1. Build a low‑voltage LED ring with diffusion and a backing plate.
  2. Power it from a waist‑mounted USB power bank using thin, concealed wiring.
  3. Optional: Add a Qi receiver inside the prop and place a transmitter behind fabric for short‑range, low‑power lighting. “Form, not function” keeps it safe and convincing. [Elektroda, Jawi_P, post #17023547]
What are the key failure modes for near‑body wireless power?
Foreign objects (coins, keys) can heat in the field; Qi uses FOD to cut power. Misalignment lowers efficiency and raises heat. Coils and ferrites can overheat in closed cavities. Design for temperature limits, shutoffs, spacing, and alignment aids. “Qi wireless power standard”
Is there any standard or certification I should follow for wearable wireless power?
Use Qi‑certified transmitter and receiver modules for wearables and small devices. Certification enforces alignment, power limits, and foreign‑object detection to reduce heating and exposure risks. Avoid custom high‑power links near the body without rigorous compliance testing. “Qi wireless power standard”
Could we use “air as fuel” for fusion or annihilation?
No. Fusion needs suitable isotopes (e.g., deuterium, tritium), and annihilation requires antimatter. Talk of annihilating ambient air is not a practical or safe power concept for engineering. [Elektroda, Madrik, post #19605443]
Are there off‑the‑shelf parts for low‑power wireless power experiments?
Yes. Use Qi‑certified transmitter/receiver dev kits and matched coils from vendors like TI, NXP, or Würth Elektronik. Follow certification limits, thermal design guidance, and foreign‑object detection requirements for safe operation near the body. “Qi wireless power standard”
