CCTV camera connected directly to the TV - and the image quality
rafal1988 6852 5
  • #1 17022971
    rafal1988
    Rate: 24
    Colleagues are looking for a simple surveillance camera. I would like to see the house entrances and the image directly on the TV monitor, bypassing the use of the recorder. Is such a thing even possible? I have a small 32 "Full HD TV that I would like to use. Are the cameras on the allegro cctv 4in1 Analog / AHD / TVI / CVI able to display a relatively legible image from the wrong bnc via a TV adapter. Please give feedback and suggestions.
    Moderated By suworow:
    I separated from the topic:
    https://www.elektroda.pl/rtvforum/topic3416062.html
    Advertisement
    We invite you to read the other guides, highlighted topics, articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security Systems Tutorials
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Tutorials
  • #2 17023098
    xury
    Automation specialist
    Help: 878
    Rate: 1498
    directly on the TV from the multi-system camera you will get only the standard CCM image. That is, poor quality.
  • #3 17023158
    rafal1988
    Rate: 24
    i.e. a typical analog image 960 x 576 - 960H?
  • #4 17023579
    Gutek1512
    Help: 39
    Rate: 37
    You will not find a camera that gives a signal on TV and with recording on an SD card. I have not crammed these into my hands yet, nor have I heard them.
  • #5 17023592
    rafal1988
    Rate: 24
    I do not care at all about video recording, be it a disk or an sd card. I just want to have the camera image directly displayed on the TV.
  • #6 17025345
    .:Marcin:.
    If it is a smart TV, you can install the application for IP cameras.
    If not, consider buying the cheapest model of the recorder and connect the camera through the recorder.
    You can connect the multi-system camera to the TV only in analog mode (not hdvci or ahd etc.) and in this mode they do not work well and the resolution will also be low. Enough to see if someone is standing or not, but definitely not hd.
    Alternatively, if the TV is not smart, you can buy a smart TV "dong".
