Windows 10 Update Error 0xc000012f: Failed Program Launch, CMD Fix, Graphics Card Drivers
tolekt 6546 7
  • #1 16831149
    tolekt
    Hello!
    After updating Win 10, after turning on most of the programs, this error appears, I tried to fix it with cmd but unfortunately the reinstallation of programs and drivers from the graphics card or running as an administrator did not work.
  • #2 16831183
    atomic99
    Help: 171
    Rate: 338
    Depending on the version of the system (which you did not specify) you have to extract and copy to the appropriate folders:
    32bit Windows:
    - 32bit file version to -> C: \ Windows \ System32
    64bit Windows:
    - 32bit file version to -> C: \ Windows \ SysWOW64
    - 64bit file version to -> C: \ Windows \ System32
    • msvcp140 (64-Bit).zip (187.14 KB) You must be logged in to download this attachment.
    • msvcp140 (32-Bit).zip (145.74 KB) You must be logged in to download this attachment.
  • #3 16831431
    tolekt
    I have 10 (64bit) win Unfortunately, even after replacing the files provided by you, some programs, e.g. razer synapse, still cause such an error.
  • #4 16831482
    safbot1st
    Help: 2719
    Rate: 1585
    Replace SMART HDD from CrystalDiskInfo.
    tolekt wrote:
    Reinstallation of programs and graphics card drivers did not work
    graphics card and driver programs or buggy programs?
    You have TeamSpeak to install again and not hide the secret about what software we write.
    We advise against overlay installations, because there are problems. The system is installed on clean partitions, because "stacking" comes out "sideways".
    You run old programs under the new system and you are surprised. Install from scratch.
  • #5 16831569
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Also install Microsoft Visual C ++ 2010 Redistributable Package in 32 and 64 bit versions.
  • #6 16831596
    atomic99
    Help: 171
    Rate: 338
    @tolekt Install these packages (Microsoft Visual C ++ Package), in Windows 10 many programs and games require them to work properly:
    • VC_redist.x86 2017.exe (13.76 MB) You must be logged in to download this attachment.
    • vc_redist.x86 2015.exe (13.13 MB) You must be logged in to download this attachment.
    • vcredist_x86 2013.exe (6.2 MB) You must be logged in to download this attachment.
    • vcredist_x86 2012.exe (6.25 MB) You must be logged in to download this attachment.
    • vcredist_x86 2010.exe (4.84 MB) You must be logged in to download this attachment.
    • vcredist_x64 2010.exe (5.45 MB) You must be logged in to download this attachment.
    • vcredist_x64 2012.exe (6.85 MB) You must be logged in to download this attachment.
    • vc_redist.x64 2015.exe (13.9 MB) You must be logged in to download this attachment.
    • VC_redist.x64 2017.exe (14.52 MB) You must be logged in to download this attachment.
    • vcredist_x64 2013.exe (6.87 MB) You must be logged in to download this attachment.
  • #7 16831619
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    @ atomic99 why did you put it all together? The files are available on the MS site, just provide the links.
  • #8 16831677
    atomic99
    Help: 171
    Rate: 338
    @ Kolobos It is not enough to provide the link, because in order to download these files you have to confirm something there a few times, choose the language, etc., and finally the download is displayed from the machine.
    I attached it because I had all the packages at "hand", it will probably be easier to download and it will stay for the future.
    • vcredist_x86 2008.exe (1.74 MB) You must be logged in to download this attachment.
    • vcredist_x64 2005.exe (3.05 MB) You must be logged in to download this attachment.
    • vcredist_x64 2008.exe (2.26 MB) You must be logged in to download this attachment.
    • vcredist_x86 2005.exe (2.6 MB) You must be logged in to download this attachment.
After updating to Windows 10, users are encountering error 0xc000012f when launching various programs. Suggested solutions include copying the appropriate file versions to system folders based on the system architecture (32-bit or 64-bit), reinstalling Microsoft Visual C++ 2010 Redistributable Package, and avoiding overlay installations of programs. Some users report that even after these fixes, specific applications like Razer Synapse still trigger the error. It is recommended to install programs from scratch on clean partitions to prevent compatibility issues with older software.
