Pop-up Error at 15% Installation: Windows 7, 32-bit & 64-bit, Error Attachment Included
gangster222 4425 4
  • #1 16889690
    gangster222
    During the installation of the system (about 15%) I get an error which is included in the attachment. I tried to install the system from two different boards, one 32-bit, the other 64-bit, but still the same :(
    Thank you in advance
  • #2 16889899
    arekopo
    Help: 8
    Rate: 41
    search the internet for what this error code means :) , I found something like this and I guess some things on your computer but you did not describe it.
    What is 0x80070570 and How do I Fix It?
    There are some bugs that you come across while using your computer and fixing them at an early stage is always better than keeping them out. Such errors, if not taken care of early, can cause greater harm to your computer not only on the software level but also on your computer hardware. One of the most common errors faced by Windows operating system users at one point or another is the error code 0x80070570. This error mainly occurs when upgrading from one version of the Windows operating system, say Windows Vista to a higher version like Windows 7.
    What is the error code: 0x80070570?
    The error messages are along with the error codes mainly to give the user an idea of what could possibly be causing the error. The error code: 0x80070570 also gives a message that mainly says the file or directory is damaged or otherwise unreadable. This error basically occurs when Windows takes updates automatically or is taken manually by a Microsoft user. The computer displays a message to the user that the required files for completing the installation are not found. They may be corrupted or missing, so the user must ensure that all files required for installation are available before restarting the installation process. This error can eventually land your computer into various other issues like freezing, gadget inefficiency, hardware failure and abnormally slow down of machine user activity.
    What could be the possible causes of this error?
    There can be many possible reasons for getting the 0x80070570 error on a Windows system except for the one mentioned above. But, as the message itself sounds, the main reason is that the application cannot find the required files to complete the grading process. It can be caused due to errors in the registry settings or the other registry is damaged due to some files missing from it. The error can also occur due to the presence of a virus or malware in the computer. Computers that are not kept up-to-date are also prone to this error.
    How to fix this error?
    There are many ways to resolve this error. The most common solution to deal with this error is registry cleaning. Registry cleaning can be performed manually as well as with the help of software (Max Utilities). There are many soft goods available in the market that performs registry cleaning on performance. Cleaning the registry manually can be a bit risky as it contains a lot of important files which, if removed, can severely damage your system. Therefore, it is always better not to touch the registry without proper knowledge. Cleaning the registry usually resolves this error and the gradation is successful. Windows operating systems always need a good and effective antivirus program to protect against viruses and worms. These anti-virus programs should be updated regularly to ensure the maximum level of system security. For all these tasksare performed and precautions are taken, the system can be successfully upgraded to a newer and higher version of Windows without experiencing any error.
    Added after 5 [minutes]:
    I will add:
    This topic is as No. 1 in google when you enter 0x80070570, so here I will enter my solution to the problem.
    ORIGINAL WINDOWS 7 64 BIT:
    I pulled out one of the 2GB dice (I have 2x2gb). This solution appears in English forums (I think it was also in Polish somewhere). I do not know why this is so, but the installation only went after removing one bone.
    and in general, where do you get these 7 win installs? an error may have sneaked in the download, re-downloading may help
  • #3 16889930
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Drive, ram and drive OK?
  • #4 16890321
    gangster222
    There are many ways to resolve this error. The most common solution to deal with this error is registry cleaning. Registry cleaning can be performed manually as well as with the help of software (Max Utilities). There are many soft goods available in the market that performs registry cleaning on performance. Cleaning the registry manually can be a bit risky as it contains a lot of important files which, if removed, can severely damage your system. Therefore, it is always better not to touch the registry without proper knowledge. Cleaning the registry usually resolves this error and the gradation is successful. Windows operating systems always need a good and effective antivirus program to protect against viruses and worms. These antivirus programs should be regularly updated to ensure the maximum level of system security. After all these tasks are done and precautions are taken, the system can be successfully upgraded to a newer and higher version of Windows without experiencing any kind of error.
    I will add:
    I have an original windows board.
  • #5 16890324
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Check the framework -> www.memtest.org
    Disk -> mhdd + smart.
