Problem with installing windows 7. STOP: c000021a {Fatal System Error}
kwaper 5025 7
  • #1 16412968
    kwaper
    I have a problem when installing windows 7, BlueScreen pops up with this notification:
    The initial session process or system process terminated unexpectedly with a sta ... (the rest is not visible)
    tus of 0x00000000 (0x0000001 0x001003f0)
    The system has been shut down.
    I've seen many posts on this topic but none have helped me.
    Please help.
    (Sorry if wrong category)
  • #2 16413221
    iagre
    Help: 213
    Rate: 281
    The first installation of windows on this PC or reinstallation? If revisiting then why?
    PC specification?
  • #3 16413527
    kwaper
    Re-caused by mhdd repair of the disk.
    Atypical computer.
    Processor: Intel Xeon E5450
    Motherboard: Abit IP35
    Graphic Card: Gigabyte GeForce GTX 660 TI
    Corsair vx450W power supply
    Ram: 2gb ddr2 from GoodRam (computer still in development, so so little)
    Drive: Samsung HD322HJ
    Before that, everything was okey. Could removing the battery cause this? Could any settings in the bios have changed?
  • BIOS settings may change after removing battery
    #4 16413619
    iagre
    Help: 213
    Rate: 281
    If the result was the need to reinstall it, it was probably a breakdown, not a repair (not about the program, but about the way / course of its use) ? If MHDD was used, why? Was it clear from SMART that it was damaged ( ONLY ) disk structure without any defects beyond the disk (e.g. chipset or ATA / SATA connector) ?
    For sure? Then what is MHDD for?
    If the computer was turned off when the battery was removed, the BIOS settings almost certainly changed.
  • Installation fails across multiple disks, implicating BIOS settings
    #5 16413639
    kwaper
    The program was used to try to remove bad sectors on the disk. Yes The battery was removed when the computer was turned off.
    Added after 19 [minutes]:
    A friend of mine said yesterday that the computer has a specific system in the bios and that it needs to be set as it is installed. How is it possible?
    It is definitely not the fault of the disk because when you try to install windows 7 on others, the same happens.
  • #6 16414432
    iagre
    Help: 213
    Rate: 281
    On other computers or on other drives?
    If the program repaired the disk, the system does not need to be reinstalled - just SFC or recovery.
  • #7 16414839
    kwaper
    On other disks.
    Disk cleaning was also performed.
  • #8 16414884
    beo
    Level 37  
    Help: 298
    Rate: 238
    Insert SMART disk e.g. by running MHDD from the disc.
    With what effect? Correct bios settings are necessary - for example the disk mode. The important issue is is the original system, without any modifications?
The user is experiencing a STOP: c000021a {Fatal System Error} during the installation of Windows 7, which is linked to a previous disk repair attempt using MHDD. The user's PC specifications include an Intel Xeon E5450 processor, Abit IP35 motherboard, Gigabyte GeForce GTX 660 TI graphics card, Corsair vx450W power supply, and 2GB DDR2 RAM from GoodRam. The user suspects that removing the battery may have altered BIOS settings, which could affect the installation process. Responses suggest checking SMART disk status, ensuring correct BIOS settings, and clarifying whether the original system is intact without modifications.
