Audi A6 C6 MMI 2G: Graphics Missing After Bluetooth Module Replacement and Software Upgrade
Pfemek 10077 3
  • #1 17035419
    Pfemek
    Help: 83
    Rate: 338
    Audi a6 2006 In general, the bluetooth module was damaged, including the defect that the graphic display of parking sensors was missing. I replaced the module, the phone still did not work, despite all the codes etc. etc. correct (there was info that the phone was not installed). I did a software upgrade, in total it is flashing again from the CDs because the software version was the same or 5150. The phone started to work but there is still no graphic parktronic. In the CAR menu "audi parking system" I have grayed out, i.e. unavailable. The parktronic module is correctly coded. What could be wrong? VAG experts help ... ;-)
  • #2 17035573
    seat21
    Help: 150
    Rate: 398
    and the green mena are working
  • #3 17035809
    Pfemek
    Help: 83
    Rate: 338
    Yes it works. I looked through them and everything seems to be correctly set.
    Added after 10 [hours] 56 [minutes]:
    However, everything was not well positioned. One of the APS functions was incorrectly selected. The system works.
    Regards...
  • #4 17129563
    kaziu202
    Rate: 56
    And what exactly did you change? Because I have a similar problem and I have no idea for these settings.
