Audi A6 C6 2005 3.0 TDI MMI 2G Problem: Crack Upload, Metainfo Not Found, 5150 Version Fix
maniek_2048 7461 2
  • #1 16945501
    maniek_2048
    Hello. I have a problem uploading crack to mmi in audi a6. A message keeps popping up
    Metainfo not found. I have version 5150 in the green menu, I marked all three points as in the instructions, I even tried to burn ISO, NRG, MDS images and I don't know yet what and nothing works all the time :( did anyone have a similar problem? and how to deal with it? Please help..
    Added after 1 [hours] 46 [minutes]:
    I did it at last. If you have questions about how to do it exactly, I invite you to priv. I will try to help
  • #2 16945870
    nutergsm
    Help: 1034
    Rate: 1665
    Please provide a solution to the problem here on the forum.
  • #3 16945903
    maniek_2048
    When we download a file from the hamster, you need to unpack it and when burning to cd you should burn directly to the disc file (mmi hi and Metainfo2) recording speed 16x, I recorded in nero. These two files cannot be in any folder. We do the rest according to the instructions
