Ford Focus mk2 2005 - Flashing LED between engine temperature and fuel level
Paablo10 38244 4
  • #1 17035512
    Paablo10
    Rate: 10
    Hello. I have a problem, which is the red flashing LED between the fuel level and engine temperature. I have no idea what it is, and it lights up as soon as the engine is started. Very often it happens if the car stands near the house overnight, or when I am at work, i.e. after 8 hours of rest. First, it flashes all the time, after some time it is getting slower and finally it doesn't flash. What could it be ? What is this happening? Thank you in advance for your help !
    sanfran
    Help: 963
    Rate: 3004
    Immobilizer error.
    In the video, advice on how to read these codes
    Unfortunately, in English.
  • #3 17035604
    Paablo10
    Rate: 10
    sanfran wrote:
    Immobilizer error.
    Thank you very much ! Do you know if it can be remedied? Alone and in Polish? :) Because after the movie, I don't understand much, although I can see that the same thing is happening as for me -.-
  • #4 17035630
    sanfran
    Help: 963
    Rate: 3004
    Okay, I'll translate.
    First flashes quickly, after about a minute it starts flashing more slowly.
    You should count these slow flashes - their number. At the end of the video you have a table, find the number corresponding to the number of flashes and read what hurts him. It is not known what and how without it.
  • #5 17035645
    Paablo10
    Rate: 10
    Thanks for the help ! If tomorrow it will be again I will count :)
