What migomat do you recommend Powermat 230G Magnum 210/2 or maybe something else
kolumb66 9174 13
Which MIG welder should I buy for home use instead of the Powermat 230G or Magnum 210/2?
The thread does not confirm the Powermat 230G’s claimed 230 V / 230 A / 60% duty cycle; the safer recommendation is to skip the cheapest single-phase units and either buy the Magnum 210/2 for light home work or, better, look for a used OZAS three-phase welder [#17040588] [#19694955] The Magnum 210/2 can weld well at home, but one owner reported that after 6 years it had a broken Euro connector, a cooked transformer that was replaced at the factory, and poor potentiometers, so he would spend more and choose something better [#17040588] Another user said the Magnum 210 Easy/Synergy fulfills home tasks, so it is acceptable if your demands are modest [#18760650] A used OZAS was described as an old but simple design that “welds pretty well,” and the three-phase machine was said to give a more stable arc, less spatter, and better tolerance to voltage drops [#19693905] [#19694955]
  • #1 17040535
    kolumb66
    Hello everyone, I am going to buy a migomat, preferably a two-voltage inverter 230/400.
    I caught the eye of the magnum 210/2 and the ideal 250/2, in my opinion, they are the same, only the housings differ, but maybe someone has such a coupling and could comment on how it works in practice?
    I am very interested in the Powermat 230G, very interesting with a large range of regulation and a lot of power, but is it possible for it to have 230 V 230 A at a 60% cycle, I have already seen topics on the forum with questions about how it works, but so far no one has posted anything. Maybe someone also has such a flashing and could comment?
    Thanks for the answers and best regards :)
  • #2 17040588
    bizon_126
    Help: 108
    Rate: 566
    Read https://www.elektroda.pl/rtvforum/topic1852172.html
    I have a midi mig 210/2
    For 6 years you have been welding 45 kilos of wire and there have been some failures
    The Euro connector has broken
    I cooked the transformer, currently made of copper, it sits at the factory
    Poor quality potentiometers
    I would have spent a little extra and looked for something better
  • #3 17040968
    kolumb66
    A Ideal 250/2? because one seller recommends ideal ideal and the other magnuma ideal is said to be a Polish company known to be Chinese, but maybe access to parts and service will be better? I'm also curious about this 230g powermat, a large range of adjustment and a lot of power, maybe someone else will comment on these migrations?
    Edit:
    Hello gentlemen, I bought a magnum 210/2 yesterday, it is great, so far I tested it on 230 because I have to make an adapter because the set includes a plug and an adapter for 5 pins and I have installations for 4, but I really have no objections to welding, even with an electrode it is heaven and earth with how my old transformer welding machine welded. Even with the blue electrode it welds very nicely, we will see how it will work for a longer time :) greetings
  • #4 17069654
    wnoto
    Help: 58
    Rate: 745
    It's very nice that you came back with the answer.
    How much did you weld with the previous welding machine?
  • Magnum 210/2 purchase and initial welding impressions
    #5 18306975
    Majetta13
    Rate: 69
    Edit:
    Hello, how has this migomat been working since the purchase of the Magnum 200/2 kn. Would you buy it again if you lack something in it, maybe a different model today would meet your requirements.
  • #6 18759992
    zbyh 62
    Rate: 57
    Hello, I will dig up the topic a bit because I am at the stage of buying a migomat. I am inclined to migrate with synergy. After the initial selection, taking into account my needs, I chose 2:
    1 Magnum MIG 210 EASY synergy
    2 Inverter Migomat Powermat 220A MIG / MAG / MMA / LIFT-TIG PM-IMGS-220L SYNERGY
    My question is: is it all the same only in a different housing. Thank you for your help. Greetings.
  • #7 18760650
    Majetta13
    Rate: 69
    I have been using this magnum 210 synergia easy for several months and I will say that it fulfills its task at home. Unfortunately, I did not use the second one ...
  • #8 18760797
    zbyh 62
    Rate: 57
    I read a lot of positive opinions about this Magnum 210, while I have Powermat but MMA and it works great for my needs. Powermat is a bit cheaper, but it still costs 1600 PLN 1700 with a set with a cylinder and wire, etc.
  • #9 19692528
    pawlik118
    Help: 202
    Rate: 611
    Gentlemen, what opinions after a year?
    Currently, I also hesitate in between
    MAGNUM MIG 201 NEW SET # 1
    POWERMAT PM-IMG-230T MIG MAG TIG 230A 3in1
    Home use 2x a year .. but I like the "induction"
  • #10 19693905
    bizon_126
    Help: 108
    Rate: 566
    If I were to buy now, I would be looking for a used OZAS
    The design is old and simple and it fry pretty well
    I bought it as the second one and I am very positively surprised even though it is as old as me
    A 3 phase welder is a different quality of welding
  • #11 19694041
    freebsd
    Help: 766
    Rate: 2034
    How would your colleague present such a difference?
  • Dual sine waves improve arc stability and reduce spatter
    #12 19694955
    bizon_126
    Help: 108
    Rate: 566
    From the point of physics - overlapping AC sine waves - just see the graph - relative to a single sine wave
    From a practical point of view
    The bow does not screech, but hisses
    Arc strike much more stable
    The welder splashes less
    It is more precise [more ranges]
    It is more indifferent to voltage drops in the network
    It's like driving a Fiat CC700 and switching to a CBS 1100
    The only thing is the weight of the device
    My friend deals with a car tinsmith powermat
    after a few years, breakdowns began
    He stated that he would buy something brand-name stimulant
    He went to watch, he tested one migomat, but he was not delighted, the guest gave him a slightly larger three-phase German from the 1980s for testing
    He bought the bigger one for the final and he won't apologize
  • #13 19696480
    pawlik118
    Help: 202
    Rate: 611
    Inverter welders have a constant output voltage. So theoretically, they are not inferior to anything three-phase.
    Three-phase has an advantage over single-phase, but only in the case of transformer welders.
  • #14 19698057
    bizon_126
    Help: 108
    Rate: 566
    I was welding Magnum MAG + MMA some small single phase, I was not very happy.
    It sprayed as if there was no gas.
    This is not just my opinion.
    The owner can not boast.
    He says it's like a bomb for him.
The discussion revolves around recommendations for purchasing a migomat, specifically comparing the Powermat 230G, Magnum 210/2, and Ideal 250/2 models. Users share their experiences with the Magnum 210/2, highlighting its performance and reliability over time, while also expressing concerns about the quality of components in some models. The Powermat 230G is noted for its extensive range of adjustment and power capabilities, but users seek clarification on its performance specifications, particularly regarding its 230V output at 230A. Comparisons are made between different brands, with some users favoring Magnum for home use and others considering Powermat for its cost-effectiveness. The conversation also touches on the advantages of three-phase welders over single-phase models, particularly in terms of stability and precision.
TL;DR: Choosing a home MIG? One user ran 45 kg of wire in 6 years and said "I would have spent a little extra." Compare reliability, arc quality, and 3‑phase benefits. [Elektroda, bizon_126, post #17040588] Why it matters: This FAQ helps DIY welders pick between Magnum, Powermat, Ideal, and 3‑phase vs single‑phase without buyer’s remorse.
Is the Powermat 230G’s "230 A at 60% on 230 V" claim verified by users?
No owner in this thread confirmed that duty cycle on 230 V. The OP asked for real reports and saw none. Treat the spec cautiously and test under load before buying. Ask for a demo weld. [Elektroda, kolumb66, post #17040535]
How does the Magnum 210/2 weld on 230 V in real use?
A new owner reported very good results on 230 V. He called it "heaven and earth" versus an old transformer welder. Stick welding also felt easier. "Even with the blue electrode it welds very nicely." [Elektroda, kolumb66, post #17040968]
What long‑term issues were reported with a Midi MIG 210/2?
One user welded 45 kg over six years and listed failures. The Euro connector broke, the transformer cooked, and potentiometers were poor. He concluded, "I would have spent a little extra and looked for something better." [Elektroda, bizon_126, post #17040588]
Is Ideal 250/2 just a rebranded Magnum 210/2?
A buyer heard claims that Ideal is a Polish brand with Chinese manufacture and suspected similar internals. He also noted parts and service access might differ. No teardown proof was posted in this thread. [Elektroda, kolumb66, post #17040968]
Magnum MIG 210 Easy Synergy vs Powermat 220L SYNERGY — which is better?
A user ran the Magnum 210 Easy Synergy for months at home and said it does the job. They had no hands‑on with the Powermat, so no direct comparison was given. [Elektroda, Majetta13, post #18760650]
What price should I expect for a Powermat synergy set?
One poster cited about 1600 PLN for the unit, or around 1700 PLN with cylinder and wire. He also noted his Powermat MMA met his needs. [Elektroda, zbyh 62, post #18760797]
What are the practical benefits of a 3‑phase MIG?
A 3‑phase arc starts smoother and stays more stable. "The bow does not screech, but hisses." Expect less spatter, more precise control, and better tolerance to voltage dips. The trade‑off is weight. [Elektroda, bizon_126, post #19694955]
Do inverters erase the 3‑phase advantage?
One poster argued inverter outputs are constant, reducing 3‑phase benefits. He said three‑phase mainly helps transformer welders, not modern inverters. [Elektroda, pawlik118, post #19696480]
Why did a single‑phase Magnum MAG+MMA spray as if there was no gas?
A user reported heavy spatter and disappointment with a small single‑phase MAG+MMA. "It sprayed as if there was no gas." The owner also was not satisfied. [Elektroda, bizon_126, post #19698057]
Which to choose for rare home use: MAGNUM MIG 201 or Powermat PM‑IMG‑230T?
One shopper used a welder twice a year and liked the "induction" feature. If that matters to you, prioritize models with induction control and simple setup. [Elektroda, pawlik118, post #19692528]
How do I compare welders before buying? (3‑step test)
  1. Ask for a test weld on the exact model you’re considering. 2. Compare a single‑phase unit to a similar 3‑phase unit side‑by‑side. 3. Listen for arc hiss, check spatter, and note stability under voltage dips. [Elektroda, bizon_126, post #19694955]
Are Powermat and Magnum often the same inside with different housings?
A buyer asked this about Magnum 210 Easy Synergy and Powermat 220L. The thread offered no definitive confirmation. Compare features, connectors, warranty, and service responsiveness instead. [Elektroda, zbyh 62, post #18759992]
Is a used OZAS 3‑phase welder worth considering?
One user would buy a used OZAS today. He praised its simple design and welding quality, adding, "A 3 phase welder is a different quality of welding." [Elektroda, bizon_126, post #19693905]
Any reliability story from car bodywork with Powermat?
A tinsmith using Powermat saw breakdowns after a few years. He tested a larger 3‑phase German 1980s MIG and bought it. He remained satisfied afterward. [Elektroda, bizon_126, post #19694955]
