MIG MMA Welder for 0.5-3mm Profiles: Comparing Magnum 170W IGBT vs Ideal Praktik 200 IGBT
szymonit928 19953 5
  • Comparing Magnum 170W and Ideal Praktik 200 IGBT
    #1 17576454
    szymonit928
    Hello everyone,
    I want to buy a sheet metal welder somewhere from 0.5 to 2 mm or 3 mm profiles, of course, festive sometimes in the garage for myself. I am thinking about the models:
    - Magnum MIG MMA 170W IGBT
    - Ideal Praktik MIG MMA 200 IGBT
    Has anyone dealt with these two models and could say whether it is worth it and how with the failure rate and the welding itself. I am asking for some advice.
    I was working with the Bester 1801 welding machine every day, can it be compared to the above-mentioned models at all?
  • Ideal Praktik MIG 200 IGBT recommended from use
    #2 17576822
    RafalGT2
    Help: 77
    Rate: 223
    I have been using the ideal migomat for 2 years, although I do not weld much, I finish the second roll of wire. But I can recommend the zero problems door to door guarantee. As for me, I have a problem-free migomat, I also have a TIG ideala, and a smiga, I have exactly this model https://specnarzedzia.pl/mig-mag/6364-ideal-praktik-mig-200-igbt-spawarka-inwertorowa.html. Most of the tools are made in China, uncle, on the other hand, has an ideal welding machine for several years and he also had a lot of electrodes without any problems and he does not complain, I can also recommend :)
  • #3 17592491
    szymonit928
    Thanks for the answer, I just wanted this model, only the one I want to buy has MIG and MMA welding methods
    Have you welded with some other equipment, e.g. a bester, and could you compare? or have you welded thin sheets, e.g. from 0.6 to 1 mm, does it not burn holes like some Chinese? and do you use Argon + Co2 mix or just Co2?
  • #4 17592751
    RafalGT2
    Help: 77
    Rate: 223
    I am not a welder, but exhausts or recently I did an air inlet on the hood and welding of the bonnet and thin sheet metal, it was ok for me. As for the comparison, I can compare it to 2 other bests, but the old model is quite a few years old and it has had a lot of sleep and for me it welds much worse, as if it would weld with a lower current, I also welded some German equipment but worth a few thousand and that welded even better. I only use CO2. Buddy, I speak as a layman, I mainly do in motorbikes, I weld some exhaust, handle, etc. and for me, the ideal weld is ok, but you know I welded off 2 spools of wire, so I'm far from professed but I don't complain about the ideal
  • #6 19632799
    Wallander
    Help: 7
    Rate: 10
    From what the guys from a friendly workshop say - they weld practically nonstop - these are comparable equipment in terms of quality.
