Choosing Between Bester 1805, Bester 1900, and Magnum 200 Migomat Machines Under PLN 2,000
Kroliczek1992 8862 5
  • #1 17103513
    Kroliczek1992
    I searched the forum a bit but I didn't find any fresh topic.
    I deal with Turning and a Migomat needs up to PLN 2,000 for the company. Such a hobby is not strictly welding. Sometimes a client needs something to sing and it doesn't pay off with every duperela to go to the welder. Preferably 400v / 230v
    In the welding center they recommended me two models:
    Bester 1805
    Bester 1900
    From the description it follows that at the strongest 170A the duty cycle is only 10% and I'm not very satisfied with it.
    From my search I came across the company MAGNUM 200 or Magnum 200/3 (It is possible that I do not know the same thing)
    http://allegro.pl/magnum-polautomat-inwerter-midi-mig-200-3-mma-igbt-i6356377451.html
    For him a great plus because you can connect and the electrode.
    So my question is asked:
    Are there any other companies today that you recommend for this price?
    Best regards,
    Marcin K.
  • #3 17104104
    Kroliczek1992
    Your two examples are on 230v and I would be interested in something on 400v / 230v.
  • #5 17104503
    Kroliczek1992
    And what can you say about those who I wrote?
  • Simple transformer MIG with minimal electronics
    #6 17111047
    petrol1
    Help: 7
    Rate: 73
    Semi-automatic, transformer-based, simple in construction, no BURN BACK function - a function that prevents electrode wire from sinking to the contact tip by temporarily pulling the wire after the welding process is over,
    * SOFT START - a function that facilitates the start of the welding process by temporarily increasing the wire feed speed,
    * SPOT TIME - time welding function, used for tacking details, thanks to which it is possible to achieve equal length of welding joints. The only electronics are the plate for regulating the wire feed and the rectifier bridge (simple to repair).
