Diagnosing Volvo V40 2.0T 165KM Variable Valve Timing Sensor: Resistance and Voltage Queries
niemawolnychnickow 9261 10
How can I test the Volvo V40 2.0T VVT valve/sensor, and what resistance or voltage should it have?
You should not expect a resistance value from the VVT oil control valve: it is an on/off solenoid that supplies oil to the VVT actuator, so with no power it is closed and with power it opens [#17403867] There is also a separate Hall sensor in this system, and it can be checked with an LED [#17403883] Several replies recommend diagnosing the VVT system with proper engine diagnostics instead of trying to measure it like a simple resistor [#17403910] Since the car’s fading at low revs may come from the throttle, airflow meter, or vacuum system, those should be checked too [#17403893]
  • #1 17043333
    niemawolnychnickow
    Rate: 9
    Hello, I have a Volvo V40 2.0T 165KM.
    The mechanic at first glance diagnosed this sensor (the car dims at low revs).
    Is there any possibility to measure this sensor? He should have some resistance? Because if I understand the principle of its operation correctly, it should open / close after applying voltage, right?
    What tension should there be on the ankle that leads to it?
  • #2 17403457
    aka85
    Rate: 11
    Hello, I am not a mechanic, but from what I know it is for fading at idle or
    approaching the intersection is rather the stepper motor ...
    I don't know what the variable valve timing sensor has to do with it. best regards
  • #3 17403792
    helmud7543
    Help: 1216
    Rate: 1564
    Depending on the engine controller, the reasons may be different, but it must be taken into account that if it stabilizes them properly when parked, there is little chance that it is the fault of the idle speed control. As for VVT, a little vague description. Usually the car clinks and has power problems but fading? In what moments does it fade? I would look for symptom descriptions for Toyota (VVTi), BMW (Vanos) or Alfa (I don't remember what this system is called in Alfa).
  • #4 17403867
    milejow
    Help: 1563
    Rate: 5148
    It is not a sensor but an ordinary valve supplying oil to the VVT actuator, no power supply - valve closed, power supply given - valve open.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #5 17403883
    kortyleski
    Help: 957
    Rate: 3860
    there is both a sensor and a valve. The sensor in this car is the hall. You can check with LED.
  • #6 17403893
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    So, get the cars away from the freak ASAP.
    The 2.0T has a very extensive vacuum and airflow system, and that's where I would look for, a throttle and a flow meter.
  • #7 17403910
    dimitriew
    Help: 16
    Rate: 103
    The valve is responsible for changing the shaft control, and the sensor monitors its operation. In order to diagnose it, diagnostics should be performed in this respect. Give the car to a real specialist because he will probably read various forums in the evening and start the "exchange process"
  • #8 17404025
    Help: 1405
    Rate: 6430
    The repair should start with the information whether you have LPG and whether there is a long spin in the morning when starting up and how long it will stop.
  • #9 17975550
    aka85
    Rate: 11
    Yes, I have lpg Agis reducer Zavoli zeta s ... there is a problem with firing as the car stands longer. I took the car from the "mechanic" I found 1 problem myself. Namely, a broken O-ring on the fuel pressure sensor. It helped with firing.
  • #10 17975719
    kortyleski
    Help: 957
    Rate: 3860
    Where is your fuel pressure sensor there?
  • #11 17976177
    aka85
    Rate: 11
    The problem with firing up was not the VVT sensor but the fuel pressure regulator, but rather its O-ring which was broken.
    I wrote the sensor above by mistake. Subject to be closed
The discussion revolves around diagnosing issues with the Variable Valve Timing (VVT) sensor in a Volvo V40 2.0T 165KM, particularly related to engine dimming at low revs. Participants clarify that the VVT system includes both a valve and a sensor, with the valve controlling oil supply to the VVT actuator and the sensor monitoring its operation. Suggestions include checking the valve's functionality, as it opens with power supply, and using diagnostics to assess the system. Some responses indicate that the problem may not be solely related to the VVT sensor, with recommendations to investigate the vehicle's vacuum and airflow systems, throttle, and flow meter. Additionally, issues with LPG systems and fuel pressure components were mentioned, highlighting the complexity of the diagnosis.
