Volvo S40 2.0D 136KM 2004 - Difficulty Starting, Mileage 158,000, No Errors, 300 Bar Pressure
Mirek_Gab 7746 2
  • #1 16845849
    Mirek_Gab
    Rate: 115
    Hello. The problem concerns a car with a mileage of 158,000. engine 2.0D 136KM 2004. For some time the problem with starting up has started, i.e. during the day, it happens that I cannot start the car during the day. After the night it will fire and after driving a dozen or so kilometers and leaving, say for an hour, it does not want to start. The starter is spinning, the battery charged, zero errors after connecting to the computer, the pressure on the injection rail is 300 bar. And he lights up once and then not. Where to look for the cause? I will be very grateful for all suggestions. Best regards.
  • #2 16845997
    marcin_70
    Help: 38
    Rate: 269
    You have to make logs during start-up as it does not want to fire ... in addition to pressure, it is important:
    does he see the turnover
    is there a synchronization (shaft sensor)
    voltage on the injectors
    what temperatures he sees
    fuel flow
    best regards
  • #3 16985439
    Mirek_Gab
    Rate: 115
    Problem solved. The reason was the muck on the flow meter.
