Volvo V50 2.0D Turbine Copy Sensor: Resistance Values for Individual Pins (Photo)
M-A-T-E-U-S-Z 7578 3
  • #1 16359578
    M-A-T-E-U-S-Z
    Rate: 57
    Hello . What should be the resistance on individual pins in the turbine copy sensor as in the photo. Volvo V50 2.0D Turbine Copy Sensor: Resistance Values for Individual Pins (Photo)
  • #2 16359606
    fuelinyourblood
    Help: 226
    Rate: 1391
    Sorry what is turbine copy sensor?
  • #3 16359613
    M-A-T-E-U-S-Z
    Rate: 57
    Position sensor for variable geometry of the turbocharger
  • #4 16360278
    AuKElMe
    Help: 17
    Rate: 36
    sensor extended pin 2-3 4500ohm
    sensor pressed pin 2-3 100ohm
