[Solved] Trouble Hearing Callers on Samsung S8: Split Speaker Sound Issue & Solutions
Arekdzoj 28617 7
  • #1 19039293
    Arekdzoj
    Rate: 13
    Hello, I have been hearing the interlocutor quieter for some time, the phone is a samsung s8
    Now I have discovered that the sound is as if it were split into 2 speakers because I can also hear the voice from the bottom speaker minimally. As if the signal would split.
  • #2 19039578
    blahfff
    Help: 1036
    Rate: 1301
    Start by cleaning the speaker mesh (the one on the top). Maybe it just clogged up.
  • #3 19045651
    Arekdzoj
    Rate: 13
    I did it right away and it did nothing, rather, it is a problem with soft
  • #4 19045835
    staś pytalski
    Help: 760
    Rate: 1436
    95% of it is this mesh, as if you would look at it under a microscope, you would see it. I suggest scrubbing well with a toothbrush, a thin brush, you can gently use a window cleaner - a little bit on the brush, or isopropyl alcohol.
  • #5 19046129
    gathor10
    Help: 100
    Rate: 137
    No liquids. Do not scrub with a toothbrush, just hit the bristle a few times on the mesh and that's it.
  • #6 19048016
    Arekdzoj
    Rate: 13
    Unfortunately, I have already done it, to highlight the problem, I will say that I checked the loudspeaker with this code and during the test everything was fine, the volume was normal, but during conversations the whole time was half quieter.
  • #7 19048039
    blahfff
    Help: 1036
    Rate: 1301
    What you checked was probably the loudspeaker from the sounds (lower), because the conversation loudspeaker in the test only gives a squeak. Since cleaning does not help, the next step is to replace the speaker with a new one.
  • #8 19048193
    Arekdzoj
    Rate: 13
    A factory reset was enough.
    Regards
The discussion revolves around a sound issue experienced by a Samsung S8 user, where the caller's voice is heard quietly and appears to be split between the top and bottom speakers. Initial suggestions included cleaning the speaker mesh, but the user reported no improvement. Further advice indicated that the problem might not be related to the mesh, as the loudspeaker test showed normal volume. The final resolution was a factory reset, which successfully resolved the issue.
