Skoda Octavia I: Coding Skoda Symphony MP3 Radio for 2k3 Model with 1/2 FIS Counter
hlaalu 7497 9
What coding should I use for a Skoda Symphony MP3 radio in a 2003 Octavia with a 1/2 FIS cluster so the 01304 communication errors disappear and the radio behaves correctly?
Set the radio coding from 00201 to 00407; that combination cleared the CAN and instrument-cluster 01304 faults in this Octavia setup, while the radio continued to work normally [#16331199][#16331415] The successful test was done with a changer and 4 speakers (2 front, 2 rear), so that coding matches that equipment layout [#16331415] The 1/2 FIS cluster will not show the full radio messages anyway, so the display issue is separate from the coding fix [#16325252][#16330956] The thread also notes that the “radio code” for theft protection is different from VAG coding, so changing the coding is not about entering the security code again [#16324433]
  • #1 16317061
    hlaalu
    I installed a skoda symphony mp3 radio for my skoda 2k3 year with a 1/2 fis counter
    It causes me a communication error with the radio such as below. I suspect that with 1/2 Fis I will not see anything on the meter when it comes to radio messages but I do not understand why this error. The radio works technically flawlessly, but after locking the car it does not turn off automatically. I do not know if this is to be the case or if the radio coding has an impact on it. The radio turns off after removing the key, but you can turn it back on and leave it there by accident. From what I read, thanks to the correct coding, I will not have to enter the radio code anymore with the possible disconnection of the battery. .
    What coding should I use to stop the bug? Of course, everything is attached to the original installation
    Below, errors from CAN, meter and radio
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 6N0 909 901
    Component and / or Version: Gateway K CAN 0001
    Software Coding: 00006
    Work Shop Code: WSC 31480
    1 Fault Found:
    01304 - Radio
    49-00 - No Communications
    Control Module Part Number: 1U0 920 821 K
    Component and / or Version: KOMBI + WEGFAHRSP VDO V10
    Software Coding: 31122
    Additional Info: TMBAP21U538699838 SKZ7Z0C1867684
    1 Fault Found:
    01304 - Radio
    Control Module Part Number: 1U0 035 156 F
    Component and / or Version: Radio YD5 0004
    Software Coding: 00201
    Work Shop Code: WSC 73430
    No fault code found.
  • #2 16323780
    piotrekwoj1
    Help: 947
    Rate: 3433
    Since you say that you will turn them on after removing the key, you probably have them connected wrong.
  • K-line communication and ignition-power diagnosis for Symphony radio
    #4 16324433
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    It must be K derived otherwise it would not communicate with the radio.
    Coding has nothing to do with the radio code.
    If you replaced the meter with the radio, it would not prefer the code.
    What was on the old radio?
    There were also these errors, could you turn on without a key?
    There should be a constant plus and plus after inserting the key into the ignition, i.e. S contact.
    Communication with the radio, meter or CAN gateway that is in the meter is after K.
    There should be outputs from the radio Enable, Clock, Data from displaying messages in the meter.
  • #5 16324848
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    These radios have such options.
    hlaalu wrote:
    Symphony Mp3
    Analog or can version?
  • Questioning CAN wiring and coding for 1/2 FIS radio
    #6 16325252
    hlaalu
    The old radio was out of the factory and did not work and the excitation cable, i.e. the K line, was not cut.
    I have everything connected to the factory ankles, so it probably should be. The old radio also crashed the error of lack of communication with the radio.
    From what I read from Can.
    Having a counter of 1/2 fis I won't see these messages anyway?
    That's the question now. Do I have to additionally connect the meter to the radio with additional wires or is the topic about choosing the right radio encoding and the problem? What else can I gain by dealing with this non-communication error? Will comfort disconnect the radio or will the radio hover work with increasing speed?
    And as for remembering the code, today I installed the cruise control and unfastened the clamp, and after connecting I turned on the radio and did not call the code. So I think the counter has written the radio code.
  • #7 16325292
    grala1
    Help: 1495
    Rate: 5052
    Give a photo of the radio sockets and stickers with their description.
    Comfort there is nothing to the radio.
    Reporting should work from Gall's signal.
  • GALA snooping works despite incorrect radio coding
    #8 16330956
    hlaalu
    As soon as the radio goes out, I'll take a picture. I don't want to damage anything when taking out without them.
    Gala snooping works with the current encoding. Generally, I found something like this on the Internet. So it actually looks like everything is working even though it shows errors and the coding is wrong. Will anything else work after I deal with this bug and change the encoding? I note that I have a 1/2 Fis Can counter, so I don't think I will see RDS messages on it.
  • #9 16331199
    grala1
    Help: 1495
    Rate: 5052
    Try changing the encoding on the radio from 00201 to 00205.
    According to my descriptions, 5 is responsible for communication via CAN with a large display on the console, but I have not met something like this yet, so maybe it is a mistake in the description.
  • Encoding 00407 clears CAN and instrument cluster errors
    #10 16331415
    hlaalu
    I have a working changer and 4 speakers - 2 front and 2 rear as standard.
    So I guess more encoding 00407 if I'm not mistaken. And the large display is the one, i.e. full FIS and I have 1/2 FIS (half of the display is messages and half of the indicator)
    So I will try to give this encoding of course, but I guess there won't be any messages.
    Added after 6 [hours] 24 [minutes]:
    I set the encoding to 00407 and the errors on the can line and on the meter in Vagu disappeared forever. The radio works as it worked before, so the problem is solved :) Altogether a little art for art but 2 bugs have disappeared though :)
The discussion revolves around the installation of a Skoda Symphony MP3 radio in a Skoda Octavia I (2k3 model) with a 1/2 FIS counter, which is causing communication errors. The user reports that the radio does not turn off automatically after locking the car and seeks advice on the correct coding to resolve the issue. Responses suggest checking the wiring connections, particularly the K line for communication, and adjusting the radio coding. A successful solution was found by changing the radio encoding from 00201 to 00407, which eliminated the CAN line errors and allowed the radio to function properly without requiring a code after battery disconnection.
