[Solved] Beko K56300HEB fridge - flashing LED with exclamation mark and LED indicator
raczekkp 9105 1
  • #1 17079677
    raczekkp
    Rate: 24
    I have a problem with the Beko K56300HEB fridge error identification. The LED with the exclamation mark and the third LED of the temperature indicator plus the acoustic alarm flash alternately. Thank you for the info.
  • #2 17333784
    raczekkp
    Rate: 24
    The problem arose because the refrigerator did not reach the set temperature. No refrigerant.
    Added after 34 [seconds]:
    No set temperature achieved.
