HP rmn A867 DVB-T Tuner Drivers: Original Disc Request, Windows 8.1 Pro, Toshiba C-660
piotrbily1978 7236 4
  • #1 17066941
    piotrbily1978
    Hello, would anyone from the forums have working drivers from the original disc for the DVB-T tuner from HP rmn A867. The topic has already been discussed on the forum, but the drivers listed in the forum do not work and the tuner is listed as not installed in the device manager. I am asking for drivers and a program to watch TV on a laptop through the above-mentioned tuner. Thank you in advance for your help. Best regards.
    Windows 8.1 Pro
    Toshiba C-660
  • #3 17066972
    piotrbily1978
    USB\VID_07CA&PID_0337&REV_0201
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Install ftp://ftp.hp.com/pub/softpaq/sp66501-67000/sp66597.exe
    For viewing you can use eg VLC or another program.
  • #5 17068527
    piotrbily1978
    After entering the device identifier in google after being directed by RADU23 I found the driver and everything flashes like this doll. The problem is only that not all channels are searched by the TV watching program. I suspect that it is the fault of the poor quality of the antenna as well as the signal. Thank you very much in / in the forum member for directing me so quickly to find and deal with the problem. As I have a moment of time, I will post a link to the softwear "
    RADU23 was found and after installing I can sometimes enjoy TV in a can (TIR) on a trip
    I do not omit the Kolobus user, who also found some time to help in solving the problem. Thank you very much for your help and best regards.
    Added after 6 [minutes]:
    I do not know about adding points to people who helped me, but I think that my thanks to these people on the forum testify to my full commitment to solving my very pettish problem. Thank you again and best regards
