Toshiba 49V5863DG 17MB130S HDMI Inputs Not Working: Firmware Update Needed?
mnjoao 2880 6
  • #1 20241810
    mnjoao
    Level 4  
    Rate: 10
    Mark:toshiba
    Model:49V5863DG
    Chassis (main board, components):17MB130S
    LCD Screen/Panel (if exist):
    More informations: good afternoon.everything works on this TV except the hdmi inputs, I don't know if it's software or hardware, but for starters I would try to update the firmware, if anyone could make themselves available, I'd appreciate it
    MJOAO
  • #2 20250885
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    Motherboard to be replaced.
  • #3 20251302
    GanCegall
    Help: 339
    Rate: 1631
    It cannot be repaired?
  • #4 20251527
    jeloi
    Help: 285
    Rate: 597
    Looking for core update.In some cases it helps.
  • #5 20251907
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    You can probably replace your friend's processor. Maybe you should first check whether those pins from HDMI that should not be ground are sometimes shorted to ground.
  • #7 20252298
    mnjoao
    Level 4  
    Rate: 10
    good morning and thanks for the answer, I already updated but it didn't solve it, it must be hardware because the customer said they stopped working one after another
    manuel joao
The discussion revolves around the Toshiba 49V5863DG television, specifically addressing issues with non-functional HDMI inputs. The user suspects a firmware issue and seeks assistance for a potential update. Responses suggest that the problem may be hardware-related, with recommendations to check the motherboard and HDMI connections. A user also shared a link to a full software update that works with the 17MB130S main board, applicable to similar models. The original poster later confirmed that a firmware update did not resolve the issue, indicating a likely hardware failure.
